Back Again...
Old Feb 6, 2019 | 09:25 PM
new2Volvos's Avatar
Default Back Again...
I was talking with a buddy and he's looking to get an older volvo like my wife's. I think he said the one he was looking at is either an 88 or 89. The guy he's talking to who owns the car says the transmission in a m47. The issue is it only goes into 4th gear right now and he said it needs a clutch...that doesn't sound quite right to me as the other gears don' catch at all(my buddy said it acts like they're all neutral...no grinding...nothing). Any thoughts or anyone have a similar issue they fixed?
Old Feb 6, 2019 | 09:26 PM
new2Volvos's Avatar
88 or 89 240 dl*
Old Feb 7, 2019 | 12:02 AM
M47 is the 5-speed (as opposed to M46, which was a 4 speed with seperate overdrive, used on earlier 240s also on turbo models).
if you can put the clutch down to the floor, shift into 4th, then slowly let off on the clutch til the engine starts to lug (good luck rolling in 4th) and putting the clutch back to the floor lets the engine idle freely, your clutch is working, so its almost certainly the gearbox.
Old Feb 7, 2019 | 12:03 AM
innards of an M47...
Old Feb 7, 2019 | 04:15 PM
new2Volvos's Avatar
thanks, would a m46 bolt to an 88 b230 or would he need to salvage the m47 bell housing?
Old Feb 7, 2019 | 04:17 PM
new2Volvos's Avatar
turns out it is the gear box, metal shavings and 4th caught like you mentioned, the other gears had no grinding and car idled as if in neutral.
Old Feb 7, 2019 | 05:22 PM
bell housing is fine, but an M46 + OD is longer than the M47, so you need a shorter front half of the driveshaft, also you need the shifter with the OD switch, and the manual OD relay + associated wiring (its pretty simple wiring). if the 240 is a 88, then you can use any M46, if its a 89+, you'd need a 89+ nonturbo or 90+ turbo (or if its an older trans, cut the notch). I don't know if you can swap the bell housing between the M47 and M46...
Old Feb 7, 2019 | 05:43 PM
new2Volvos's Avatar
ok awesome, thanks for the information Pierce!
underaroof
Sep 6, 2013 09:35 AM
nweuros
Oct 5, 2012 03:43 AM
vanislehampton
Feb 18, 2010 10:11 PM
superbeetlejosh
Oct 26, 2008 01:26 PM
mecko
Mar 5, 2008 02:06 PM
