trans trouble
Old Dec 30, 2005 | 07:04 PM
ldf602's Avatar
Default trans trouble
I have a 1989 740 wagon with 120000 miles. Recently, the automatic trans doesn't always shift into 4th gear. The kickdown arrow lights up and no matter how many times i push the button on the shift lever, it does not turn off and shift into 4th gear. Sometimes it works fine. Sometimes when i turn the car on the Arrow is lit and won't go off. Sometimes it comes on when i am going 60 mph and it kicks down and the tach goes to about 5,ooo rpm.
Any thoughts on cause, cure? Thanks
Old Dec 31, 2005 | 01:37 AM
Dingbat's Avatar
Default RE: trans trouble
Check for frayed wires around your OD unit, if thats fine, its probably your OD relay. hope it helps
Old Dec 31, 2005 | 05:23 AM
seattlevolvoguy's Avatar
try the overdrive relay. it is located behind the ashtray. it is white about 2"wide by 3"tall. if that does not work replace gthe overdrive switch on your gear selector. peace
Old Jan 1, 2006 | 09:47 PM
ldf602's Avatar
thanks for the answers. After I posted, I went back and read a lot of posts and see this is a common problem. What i am not sure of is if i disconnect the cable at the trans, will the car still perform normally? I don't care about the switch working, but will i be able to kickdown by stomping on the gas?
Will I get the same result if i disconnect the relay?
Thanks, Larry
Old Jan 2, 2006 | 02:32 PM
chris1kanobi's Avatar
A Volvo auto trans does not have a 4th gear. It has overdrive (which you figured out). If you disconnect the relay, the overdrive will not engauge at all. If you hot wire it, you have a chance of running in overdrive in all 3 gears, not good. There is a way to test the relay, but I am not sure off hand what it is. My suggestion is to replace the relay, and if it is good you have a spare. If the relay is not the problem, then look at the push button and see if it is functioning properly. I have seen quite a few 700 series cars at the scrap yard here in Denver, that may be an option for replacement parts.
Old Jan 5, 2006 | 09:13 PM
ldf602's Avatar
Sorry, but more questions.... seeing as how the owners manual says to run in third when towing, I suppose it is ok to drive about 60 mph with arrow on in third? I have to drive about 15 highway miles to work. Is that ok till I can get this fixed?
How much does a relay cost? New or used, any ideas?
And finally, how do I get the switch out of the gearshift lever? Just pry it out? Should i then just make sure the connections are good and no frayed wires?
Thanks again.
Old Jan 6, 2006 | 12:17 AM
Check the relay first. I forget how much they are.
15 miles should be fine for now.
LEAVE THE SWITCH ALONE FOR NOW.
If one of the wires break you can tackle it later. You will have to remove the entire shifter assembly out of the car.
Old Jan 10, 2006 | 02:48 PM
colgate41's Avatar
OK i had the same problem.....the OD relay can be found on e-bay for 20-30 bucks, and in my case the OD relay was just loose....so i just took it out and put it back in and now my car is fine. Maybe try that? I hope i helped a little.
Old Jan 11, 2006 | 12:26 AM
ldf602's Avatar
Thanks, I am hoping thats the problem. I have seen the part on line for between $28 and $60.
In prior posts, ppl have said its behind the ash tray. I have taken my ashtray out, but only see the fuse block. I guess i need to contort myself to get down and look around in there for something besides the fuses. Is that right that it is in there?
Thanks again
Old Jan 14, 2006 | 05:06 PM
colgate41's Avatar
YES, the relays are in there but they are far back and you will need to take out the whole fuse block. Don't worry, its easy.
Old Jan 15, 2006 | 05:20 PM
ldf602's Avatar
Thanks colgate. It's pretty cold out now and i don't have a garage so i'll check it on a warm day, or when i can get some garage time. I'll let you know how i make out.
VolPat
Jun 15, 2012 08:06 PM
ded137t5r
Jun 10, 2012 07:40 PM
Eric's Hot Rod Shop
Jul 14, 2011 08:26 AM
VTBricked
Nov 21, 2009 07:50 AM
ldf602
Sep 4, 2007 09:43 PM
