belts 86 740 turbo wagon
Old Jan 5, 2007 | 12:23 AM
txturbo's Avatar
Default belts 86 740 turbo wagon
Buying all new belts tomorrow. I noticed the a/c and alternator have double groove pulleys.The crank is three groves. Right now the a/c doesn't have a belt, one belt goes around the fan and p/s, the other belt around the fan and alternator. Looks like the rear groove is for the fan and p/s. Are there suppose to be two belts going around the front two crank grooves, fan, alternator and a/c?
Old Jan 5, 2007 | 12:31 AM
Default RE: belts 86 740 turbo wagon
I think someone might have a wrong belt on there or something.
I believe one goes to the crank water pump and alt
one power steering to crank
Then the A/C to crank.
Some of the cars have 2 alt. belts. others have one.
Old Jan 5, 2007 | 12:34 AM
txturbo's Avatar
Ok....thanks. I wasn't sure because I didn't take them off. I thought maybe someone used shorter belts when they decided to disconnect the a/c compressor. So even though the a/c compressor and alternator have double groove pulleys, they only use one belt each?
Old Jan 5, 2007 | 12:41 AM
The A/C uses one But sometimes the steering is run off the A/C to. Then 2 would be used.
But I forget exactly.
See to many cars all day long.
Some run the steering off the A/C. Then the Alt. uses 2 belts.
If the steering isn't run off the A/C the Alt. would use 1 belt.
Sorry maybe someone else reading this post might have the same car and be able to look at their's and let you know.
Old Jan 5, 2007 | 12:51 AM
txturbo's Avatar
I know what you mean. The p/s is on the opposite side from the a/c. I'll just run one belt to each one.
Old Jan 5, 2007 | 12:59 AM
Ok then the Alt. would only have one.
JamesG
2001-2013 model year V70
Oct 22, 2014 09:45 PM
rcoonce
Dec 2, 2007 09:51 AM
JPizano23
Sep 4, 2005 01:32 AM
blac70
Jul 21, 2005 10:30 PM
Daz_C70
Jul 12, 2005 06:29 PM
