Best way to test FPR??
Old Aug 31, 2008 | 01:50 PM
Forsyth's Avatar
Default Best way to test FPR??
1990 740 GL *Regina* 291,500 miles
I was wondering if there is a simple, but accurate way to test for a good/bad Fuel Pressure Regulator.
I read that you can take the hose off the front and the idle should increase and if not it is bad.
However, it seems like has little tiny surge but not much, should it increase to 1200 and stay when hoses is removed or just surge way up then back down?
Thanks in advance
Old Aug 31, 2008 | 10:30 PM
Default RE: Best way to test FPR??
Is there fuel in the vacuum hose?
The best way to test is really to use a fuel pressure guage.
Old Sep 1, 2008 | 02:56 AM
Forsyth's Avatar
Thanks for the response, no there is no fuel in the vacuum hose.
I'm kinda new at this stuff, if i were to get a Fuel pressure guage would it be self explanitory, or does it hook between one of the hoses and the fpr?
[ http://i60.photobucket.com/albums/h1...DSCF0653-1.jpg]
Also, I don't know if FPR have an average life span, but I'm pretty certain this one is original with 291.5k miles on it. As well as when I changed the flame trap, which was brass, but may have been cleaned since my engine has no leaks.
One other question, I've seen some sites say their FPR covers 80s to like 92, also seen on ipd bosch only, then on fcpgroton that you can find one with regina in the name too, so I'm thinking i have to have regina-unless these piece does not matter which fuel system you have, which is like double the price. [ifI need one]
Thanks again for all the help
Old Sep 1, 2008 | 08:14 AM
For the fuel guage you would need one that goes inline with the fuel line to the fuel rail.
A bosch FPR will work fine. Just make sure you have the proper part# for the regina system.
Old Sep 1, 2008 | 01:31 PM
Forsyth's Avatar
Thanks again
hookuspookus
Jul 2, 2024 02:52 AM
ricky
Aug 22, 2009 05:29 PM
mountaineer
Feb 4, 2009 04:56 PM
rupert77
Jan 25, 2009 05:18 PM
bkraff18
Jun 24, 2008 08:45 AM
