biggest tires to put on 1991 240 dL?
Old Dec 30, 2011 | 09:32 PM
itr's Avatar
itr
Default biggest tires to put on 1991 240 dL?
1991 240 DL 4 doors, 200K miles., Ipd sport springs and Belstein touring shocks. My daughter's transportation to and from college.
It is about time to replace tires (stock 14" steel). Do not want to spend more money on rims. Currently has 195/70/14 on. I would like to know what is the largest tire I could put on without causing any problems e.g. rubbing, hitting the fender liner, etc.
Thanks in advance for the helps.
Old Jan 1, 2012 | 07:33 AM
swiftjustice44's Avatar
Good luck...it's tough enough finding 14" tires in any size let alone oversized.
Old Jan 1, 2012 | 07:01 PM
purv420's Avatar
You are currently running the largest 14 size.
Old Jan 1, 2012 | 07:18 PM
jagtoes's Avatar
What are you trying to achieve. You can get a set of15" Volvo rims at a salvage yard pretty cheep. Then you have a lot better tire selection. I have a set of 15" with snows and a set of aluminum wheels with summer tires. I also have a set of 15" that I once bought from tire rack.
Rick van Draaijen
May 9, 2015 04:19 AM
ehobart
Jun 15, 2014 02:43 PM
Scott S
Jun 21, 2011 06:55 PM
jsenge
Jan 30, 2007 09:30 PM
HES2QUICK@aol.com
Jan 30, 2006 01:52 PM
