Bilstein B4 Rear Shock Noise?
Old 02-13-2023, 03:45 PM
doublerun's Avatar
Question Bilstein B4 Rear Shock Noise?
Recently bought Bilstein B4 shocks and struts for my 93 Volvo 240 sedan. I've been reading that the rear shocks are known to make some noise because the inner bore diameter of the anchors is a little too large. Seems like I should have done a little more research prior to purchasing. So my questions are as follows:
Can anyone verify this?
Is there any way to correct it?
I would prefer not to return these but if the noise is that bad I suppose I ought to.
Thanks
Old 02-13-2023, 07:36 PM
Are you sure its the shocks making the noises or somebody not doing a proper install. Things like over tighening bushings etc can pass along noise and vibrations. Curious of your source for this concern - probably a BMW forum LOL
Old 02-14-2023, 12:32 AM
doublerun's Avatar
A review for the product on IPD's website mentioned it and another "confirmed" that's just the way it is: https://www.ipdusa.com/products/4955...1206641-106058
Bilstein's actual website seems to agree with you: https://workshop.bilstein.com/en/ban...he-suspension/
I can't find anything to corroborate the claim though. I'd be more inclined to trust the manufacturer than some random reviewer but I just want to be thorough
Old 02-14-2023, 05:04 PM
personally, I'd chose the Boge/Sachs shocks over the Bilstein B4s. The 4s are a more standard design vs the B6s (ake Bilstein Heavy Duty) so for similar money you get the OEM brand, which is a good match to the stock springs. I've done boht B6s and Boge OEMs so I don't have a brand bias.
Old 02-14-2023, 10:48 PM
doublerun's Avatar
I intend on buying IPD's 240 lowering springs here in the next couple of weeks and I don't think those Boge/Sachs are compatible with anything but stock springs. Feel free to correct me on that maybe I was looking at the wrong ones. I was on the phone with a guy from IPD and he said the B4s should work with them just fine.
Old 02-15-2023, 08:53 AM
Yes IPD says their springs are "designed" (chosen?) to work with stock components which would include Boges or the B4s. Note if you are looking for better handling vs a better stance, do the IPD sway bars and HD end links first. I had the IPD bars on my 850T wagon and it made a huge difference (to the point I wondered why Volvo didn't spec stiffer bars as a factory option). Post up how you make out :-)
ngshinong
02-14-2014 09:27 AM
talamant3z
08-08-2012 03:25 PM
iceracer46
11-08-2011 09:32 PM
rae8525
07-25-2009 08:28 AM
brutt
01-30-2008 07:31 PM
Quick Reply: Bilstein B4 Rear Shock Noise?
