Blower Motor Replacement - 1990 740GL Wagon
Old Jan 11, 2014 | 01:31 AM
ianwarsenault's Avatar
Default Blower Motor Replacement - 1990 740GL Wagon
Picked up a blower motor today from NAPA (BK 6552407) hoping to replace a recently failed one in my wagon.
When I got the old one off and compared the two they look more than a little different (photos below).
Anyone else have a similar experience, advice or any ideas on where I can pick up the right one?
The label on the old one reads:
Valeo
A 03/15/02
22137253
12.0V 48293
***Note: The wiring on the NAPA unit is nothing more than me trying to "make it work."***
Thanks,
Ian
Old Jan 11, 2014 | 01:51 AM
it appears Volvo no longer sells the originals.
IPDusa.com sells this one,
Heater Blower Fan Motor
fcpeuro sells that one and 2 others, the cheapest of which looks kinda like that one you got
Volvo 740 Blower Motor Parts | FCP Euro
I'd probably get the VDO
oh. it looks like 740 blower motors changed after 1988, per some info on the fcp site, the single wire version might be for 1983-1988, while the two wire versions are for 1989+ 740 and all 940.
Old Jan 11, 2014 | 02:18 AM
Thanks for the info, Pierce.
The VDO looks best to me as well. I'll keep you all updated on my progress.
Old Jan 11, 2014 | 02:31 AM
you might clean the contacts and connectors on the resistor pack thats stuck on the outside of the air ducting... I'd probably replace it if it looks like its too baked (often old dying motors will overstress the R-pack). the various pins and resistors are used to slow the motor down to different speeds (on my 92 740 there's 5 speeds). I don't use speeds 4 very often, that likely puts the most stress on the resistors (speed 5 bypasses the resistors entirely, speed 4 goes through 1 resistor, speed 1 spreads way less current through all 4 in series)
Old Jan 15, 2014 | 04:50 PM
Just had the new fan delivered. Looks just like the old one. The directions, however, are telling me to use a hacksaw and the provided adaptor ring.
In my opinion, if it fits, you don't cut or modify anything... unless, of course, there's a good reason to.
Is there any reason to not just use the existing housing unmodified?
Deep thoughts.
Old Jan 15, 2014 | 05:01 PM
ummmm, if it fits, use it as-is.
i wonder if those instructions aren't confusing the older version for the newer?
the picture on FCP's website of the VDO fan *looked* just like the original 'new' version, while that other one they had was 'adaptable' and had an adapter ring or whatever.
Volvo Heater Blower Motor (740 760 780 940) - VDO 30676867 | FCP Euro
Old Jan 15, 2014 | 06:26 PM
Popped it in and it fit like a glove without any modifications. Doesn't seem to push air as well as the old one did but I'll take some heat over no heat any Chicago winter day.
I'll do some more troubleshooting when the days get a little warmer.
Thanks for your help, Peirce.
Old Jan 16, 2014 | 11:40 PM
A funny thing happens when you plug the fan in the wrong way. Since it's DC, it'll spin the wrong way.
I pulled the panel and saw that that's exactly what I did (The coupling on the FCP's VDO fan can be connected either way).
So, now that it's spinning the right direction, it works like a champ.
HunnyBunny
Dec 14, 2010 07:18 PM
igtc
Jan 21, 2006 01:53 PM
dan987
Jan 13, 2006 01:44 PM
derek_d
Dec 28, 2005 09:15 PM
cj_magnatta
Jun 18, 2005 08:25 PM
