On body work
Old Jul 2, 2009 | 06:35 AM
deviate240's Avatar
Default On body work
Hey everybody, new to the forums here...
Question here for anyone with knowledge on body work
So I have an '85 240 and would like to remove the trim molding from all around the outside and fill in the holes where the trim clips on. Now I realize bondo is probably a bad idea.. so was wondering if anyone out there has ever done this somehow or has experience in body soldering and could give me some info on how to do this myself. Thanks in advance
Old Jul 2, 2009 | 12:39 PM
adub96's Avatar
Bondo will fall out. You cant really solder it either. Your only option for a good job to be done and look right at removing belt trim, is to have the holes welded. Then grind them flat, then body filler for the low spots, sand it, again and again. Yada yada its a lot of work. If you don't want to do that there is a type of body striping tape that is just as wide as the flat top of the body line.
Old Jul 2, 2009 | 06:23 PM
That would be tricky...
Old Jul 3, 2009 | 06:10 AM
deviate240's Avatar
I was afraid of that.. and with the amount of holes it will probably be pricey to pay someone to do it. Striping tape is an interesting option, hadn't thought of that. I just might go with it, thanks!
86volvoguy
Apr 20, 2017 10:50 PM
Nic Graner
Jan 5, 2013 10:39 PM
JPizano23
May 21, 2009 08:01 PM
gordon368
Nov 30, 2007 09:22 PM
Road Hazard
Dec 9, 2003 06:06 PM
