Bumper color?
Hello
i was wondering what color was the bumper of my 1995 940? right now its like washed up black, but i dont know if when new was full black, any product to put the original color back?
Im pretty sure when brand new it was all black. With age and weather etc... these bumpers fade, but if you get scotch pads from a food store or somthing you can buff the gray-ish out. It is somewhat of a quick fix and if you keep it up your bumpers will look pretty good, not the orginal black but better than a faded grey. Hope that helps. P.s. Those scotch pads are about 2 bucks.
I did not take the bumpers off. I used the sponge applicator that came with the product for the big areas being careful not to get on the paint. I used a small artist brush (very small pointed tip) for those areas near the body and paint. Some tips I learned:
Do not do this in direct sunlight ( in the garage with plenty of light)
Make sure to paint to the wet area (just like house painting)
Keep on hand some mineral spirits in case you get to the paint by mistake
Use blue masking tape to tape off large areas so you dont get to the paint
Make sure to brush out all of the bubble and streaks
I took me two coats to get the look I wanted as some parts of the trim will just soak up this stuff.
I dont think that I missed anything, but take our time and make sure to have some plactic sheeting laying out where you are working as this stuff sometimes will drip from the sponge appricator and when it hits the garage floor...forget it. The plastic is cheap and it is what DIY'er used when painting inside.
RedBrick
RedBrick
Fianlly able to clean, clay, wax and do bumpers and trim again. The final results.
RedBrick
http://pg.photos.yahoo.com/ph/fap_su.../ph//my_photos
RedBrick
