Bushings question
Old Aug 31, 2013 | 11:00 PM
91-740Turbo's Avatar
Default Bushings question
Came across replacement bushings off of IPD and saw that there are rubber and polyurethane bushings for the suspension. I was curious about the difference between the ride between the two. Supposedly the ride with the polyurethane is a little more stiff and/or rough compared to the rubber ones. Would it make a considerable difference?
Old Aug 31, 2013 | 11:32 PM
I would use volvo brand rubber bushings all the way around, unless you're building a track car for racing. if you do go poly, use only SuperPro brand poly, the chinese poly stuff is junk.
poly bushings will give the car a very tight ride, harsher on rough roads, less forgiving. they also likely won't last as long as OEM rubber.
Old Aug 31, 2013 | 11:35 PM
Hmmmmm, good point. I tend to go on some gravel roads at least once a week. Don't think that I'll want to go to work already sore from just the ride to it.
Old Sep 1, 2013 | 12:08 AM
I'd also suggest sticking with stock spring rates and boge progas shocks (or whatever they are called now, these are the OE shocks).
I put bilstein 'touring' on mine, and they are too harsh for the rougher roads around here.
Jbthomas921
Aug 19, 2010 05:54 PM
montgb
Oct 14, 2009 07:16 AM
Platinum52
Jul 17, 2009 07:33 PM
MikeNorris
Nov 9, 2005 01:29 AM
knight rider
Jun 29, 2005 07:44 PM
