Cam timing
Old Feb 21, 2014 | 07:11 AM
danielp's Avatar
Default Cam timing
Hi all,
Just in the process of doing the cambelt. Got it all stripped down, got the pulley off. Just looking at the markings, the bottom pulley... How does it locate on the crankshaft? There is a cut out for what looks like it should slide into a woodruff key or something similar.
IMG_0180Small2.jpg?t=1392987818
You can see on the pulley where it has been fitted but from what I can see there is nothing that will locate it. As there is a marking for timing the engine there has got to be a way of locating it in a set place..
Just another addition...
Fitted the belt, the cam and dizzy pulley marks line up on the belt. The double mark for the crank doesn't line up with any mark on the crank gear pulley, which one is it suppose to line up with?
'89 2.3 B230E
Thanks,
Dan
Old Feb 21, 2014 | 12:49 PM
fochs's Avatar
It looks like the crankshaft guide pin has sheared off. Remove the guide plate from the crankshaft sprocket and see if you can get the remnant out.
This:
Home
shows a little more clearly the process and marks. Scroll down to: Now Here! (A step by step guide to changing the timing belt....)
Old Feb 21, 2014 | 02:58 PM
danielp's Avatar
hmm, that would explain it... it looks like someone knew about it!
Ho hum.. least it's not difficult to get back off.
Thanks fochs! Much appreciated
Dan
Old Feb 22, 2014 | 11:29 AM
danielp's Avatar
I've had a look today at the crank pulley timing gear. It looks like at some point the crank pulley has worked its way loose, spun and worn the nub down used for locating the pulley.
So I marked the pulley and on the timing gear and used that to line it up.
Since doing the cambelt I have noticed that the idle speed has increased... not sure why. Going to set up the ignition timing see if that's the issue. Also the idle isn't smooth, never has been you can see the engine rocking at idle
Thanks for the help!
Dan
erndawg
Feb 13, 2009 10:14 PM
Crate45
Jul 7, 2008 10:34 PM
Soloracer
Aug 26, 2006 04:43 PM
Carbuff
May 19, 2005 04:44 PM
