Can I put a 1992 Volvo 240 Fuel Pump in a 1990 Volvo 740 Turbo?
Old Feb 6, 2020 | 12:38 PM
Alriar's Avatar
Default Can I put a 1992 Volvo 240 Fuel Pump in a 1990 Volvo 740 Turbo?
So I'm trying to get a Bosch fuel pump for my 1990 Volvo 740 Turbo, preferably off FCP Euro, but they only have a $200 genuine Volvo part. So I did a little looking around and noticed one RockAuto they're selling a fuel pump for my car that looks just like the one I have for my Volvo 240. To give you an idea, the Volvo Fuel Pump In-Line - Bosch 69593 is for the Volvo 240 while there's a Volvo Fuel Pump In-Line - Bosch 69594 for the Volvo 740 Turbo. They look IDENTICAL. Any chance I can get away with putting the 240 pump on the 740?
Thanks,
Noah
Old Feb 6, 2020 | 03:49 PM
turbos need significantly more fuel per second under heavy throttle, I don't think the non-turbo pump can keep up.
Old Feb 6, 2020 | 07:50 PM
Goldenblock's Avatar
You can do it if you have the 2 pump bosch system! Make sure your inline fuel pump is specifically for Turbo. With either green or black stripe on it...
Goodluck
Old Feb 6, 2020 | 11:34 PM
Goodluck
the 240 pump is nonturbo with a yellow stripe, thats what he wants to use in his 740 turbo.
the number he gave for the 740 turbo pump is this one
https://www.amazon.com/Bosch-69594-Original-Equipment-Replacement/dp/B000BZL9QI https://www.amazon.com/Bosch-69594-Original-Equipment-Replacement/dp/B000BZL9QI
Old Feb 7, 2020 | 01:06 PM
Yeah man you ll be fine! As long as the car aint boosted up 350 horsepower, the pump will be fine we did it before many times!
fyi i do have several inline Oem pumps available also!!
Oss Goldenblock 2 million miles plus!!!
Old Feb 7, 2020 | 01:18 PM
a 740T wagon can suck down 8MPG or worse doing heavy throttle launches or uphills in middle RPMs. at 60MPH, thats a pint a minute, and it has to deliver that while maintaining the fuel pressure of manifold+42 PSI, where manifold can be ~8 PSI above ambient due to boost, so that means 50 PSI or so. a N/A B230F will never drop below about 15 MPG, and wide open throttle is 0 psi 'vacuum', so the max fuel pressure is 42 psi
the turbo pump is capable of significantly higher volumes than the NA pump. That's why they have two models.
Old Feb 11, 2020 | 06:05 AM
act1292's Avatar
As Pierce stated, the turbo requires a higher flow rate than the standard pump. You need to get the turbo pump suited for your car.
Old Feb 11, 2020 | 01:53 PM
well, you could probably drive a turbo like a little old lady, never using full throttle or full boost, and get away with a regular pump... but if you find yourself at the edges, fuel starvation leads to lean mix leads to excessive combustion temperatures leads to burned valves and pistons
joedrt77
Oct 3, 2016 12:23 PM
goto
Sep 19, 2016 09:33 AM
92_240_sedan
Jan 14, 2013 07:31 PM
greylady
Sep 15, 2011 01:04 PM
teless242
Aug 17, 2011 01:41 AM
