How to replace regina fuel pumps.
Old Jan 14, 2013 | 01:44 PM
92_240_sedan's Avatar
Default How to replace regina fuel pumps.
The one in the tank i can imagine is simple to dissasemble, but there is one under the car right? How hard is that one?
Old Jan 14, 2013 | 01:55 PM
on a regina FI system, there is only the in-tank pump, but AFAIK, 1992 240's are purely Bosch, it was the 740/940s that came both ways.
the under-car pump is a lot easier to replace than the in-tank one. jack up car, put on stands (or a proper lift), drop the pump assembly plate, disconnect pump, install new and replace the filter while you're there (its right next to it), and reinstall, varoom. thre's some rubber mount pieces you might want to replace too, they keep the pump vibration quiet.
here's the parts diagram for a mid production 240 main fuel pump assembly ... your 92 is essentially the same, although some of the PN's might have changed.
Old Jan 14, 2013 | 02:21 PM
lev's Avatar
lev
I assume you have a Regina, in a '90 740 N/A? Then you have ONLY ONE pump in the gas tank... Then see this:
Fuel System: Pumps, Relays
Old Jan 14, 2013 | 02:27 PM
so wait, reginas only have ONE pump? its for a 90 740 gl
Old Jan 14, 2013 | 03:03 PM
yes, most Reginas only have the in-tank pump, which is a high pressure pump.
read all about it here,
Engine: Fuel Injection
there are (somewhat rare) 2 pump regina cars, and there are 1 pump Bosch cars. Fun?
here's the tank pump replacement procedure.
Volvo Fuel Tank Pump/Sender Replacement
Old Jan 14, 2013 | 07:04 PM
lev's Avatar
lev
There are NO 2 pump Reginas, the only One pump Bosch is the 1995 940.
Old Jan 14, 2013 | 07:31 PM
these guys say there were some 2 pump reginas in the 89-92 timeframe
maybe that was just in .EU/.UK ? I could see volvo putting a regina engine in a chassis that had bosch pumps, as both systems use the same fuel pressure and flow rates.
a side note, I've also heard the 95 bosch single pump works quite well as a replacement for single pump regina cars, and is a better and more reliable pump.
this same pump was used in many newer volvo models like 850's.
rmensah
May 31, 2010 09:54 PM
hairyg
Jul 15, 2008 12:23 PM
junkmorning
Sep 8, 2006 05:15 PM
Lucky_Avalon
Engine & Internal
Jul 20, 2006 12:58 AM
whyflygti
Sep 26, 2005 12:42 AM
