Hood Hinges are completely bent
Old Mar 15, 2008 | 02:50 PM
DeFoaBuSe's Avatar
Default Hood Hinges are completely bent
afsfaf
Old Mar 15, 2008 | 02:55 PM
Default RE: Hood Hinges are completely bent
Link doesn't work.
I would remove the hood and try to get junkyard hinges.
Old Mar 15, 2008 | 08:32 PM
Volgrrr's Avatar
ORIGINAL: tech
Link doesn't work.
Ditto
Old Mar 16, 2008 | 10:28 AM
Psaboic's Avatar
Don't waste the time trying to fix the bad hinges. Even if you do get them fairly straight, they have been weakened by being bent and then hammered. Also, check your hood latching system and the latches themselves. The system is supposed to "double latch" to prevent accidents exactly like this.
Goood Luck
Old Mar 16, 2008 | 11:53 AM
DeFoaBuSe's Avatar
asfgb
Old Mar 16, 2008 | 12:32 PM
Rivets are fastners that you use a tool to compress the rivet and the rivet expands to hold the items into place.
Old Mar 22, 2008 | 10:13 AM
DeFoaBuSe's Avatar
agdffag
Old Mar 22, 2008 | 04:25 PM
As far as I know the inner fender liner should only be held in with Rivets. You can just cut the head off the rivet with a decent set of wire cutters.
http://docthrock.com/canopy3_files/P...stRivetGun.JPG
Picture of rivet gun
http://aolsearch.aol.com/aol/imageDe...query%3DRivets
Picture of rivets. You slide the rivet into the gun and squeeze the handles in like an open and close motion till the inner parts pops off and you are done.
Red Tractors
Aug 20, 2013 10:33 PM
likesspace
Jun 23, 2007 04:32 PM
