CHECK ENGINE CODES
Old Nov 28, 2006 | 05:19 PM
ALJOSEPH's Avatar
Default CHECK ENGINE CODES
I have a 89 740 nontubro with a check engine light on, I checked the codes and it saidf that I have a probelm with coolant temp signal I replaced the sensor and the guage and it still g9iving the same code . Place help
Old Nov 28, 2006 | 07:27 PM
billofdurham's Avatar
Default RE: CHECK ENGINE CODES
Did you erase the code?
Old Nov 29, 2006 | 07:11 PM
ALJOSEPH's Avatar
Yes I reset the codes and it it came back on after about 5 minutes
Old Nov 29, 2006 | 09:56 PM
Check the wiring harness. It might be falling apart.
Old Dec 1, 2006 | 02:02 AM
ALJOSEPH's Avatar
Will this cause the engine to be hard to start after it warmed up , I have to step on the gas in order to start, once it starts, the car run fine
Old Dec 1, 2006 | 08:47 PM
Yes it can cause that as well.
Old Dec 11, 2006 | 07:17 PM
ALJOSEPH's Avatar
This car is driving me up a wall, but I refuse to give up, I just changed the speed sensor for the flywheel, and it ran better for a few days, now it act like the air mass sensor is bad replaced it still the same, now it will start than stall, if I keep trying to start it while pumping the gas paddle it may keep runnig, is this cause by the computer , and the check engine light came back on ( codes 123-224 ) sorry if this a bit much, but I can't afford to take it in to a repair shop
Old Dec 11, 2006 | 09:28 PM
Codes are Coolant temp sensor.
How old is the coolant temp sensor?
Old Dec 11, 2006 | 11:22 PM
ALJOSEPH's Avatar
just changed it last week and the check engine came back on
Old Dec 11, 2006 | 11:47 PM
What about the wiring harness?
Old Dec 12, 2006 | 12:14 AM
ALJOSEPH's Avatar
It seems to be in tack there are no cracks in the insulation and the connectors seem to be tight, wish I had a wiring diagram or if anyone known where to check on the big plug to the coolant temp sensor, then I could check it with my meter.
Old Dec 12, 2006 | 01:28 AM
Look at the color wire at the sensor then trace back to the plug and ohm it and see what happens.
Old Dec 12, 2006 | 07:38 AM
JetTech's Avatar
Is your car an 8 valve or 16 valve engine? I can get you a schematic but I need to know which engine you have first.
Dale
Old Dec 12, 2006 | 07:53 AM
JetTech's Avatar
Here's some info that might help concerning the sensor with an 8 valve engine. I'm not sure if the resistance values are different with the 16 valve engine but will certainly look to see if you have that engine. This is the sensor that supplies temp. values to the ECU not the gauge. This sensor is a 2 wire sensor whereas the one supplying values to the gauge is a single wire sensor. From what you've said I'm guessing you replaced the wrong sensor, which is the one that supplies information to the gauge.
Coolant Temperature Sensor
At 14 deg. F. (-10 deg C) 8260 - 10560 ohms
At 32 deg. F. (0 deg. C.) 5800 - 6000 ohms
At 104 deg. F. (40 deg. C.) 1050 - 1200 ohms
At 176 deg. F. (80 deg. C.) 290 - 364 ohms
wieder
Sep 10, 2010 08:42 PM
Bruno937
Mar 25, 2008 08:31 AM
gabyman97596
May 14, 2007 09:52 PM
cranky
Aug 5, 2005 09:46 PM
