Chinese fuse stops the Ovlov again
Old Mar 8, 2011 | 05:37 AM
razzledog's Avatar
Default Chinese fuse stops the Ovlov again
So today, a cheap Chinese ceramic fuse killed the old girl stone dead. It had me fooled, so had to get poor Ovlov towed home. All seemed OK this morning but at midday the engine died shortly after startup. I have been caught with fuel pumps dying a couple of times, resulting in blown fuses..then caught out with frayed engine harness causing more fuses to blow too, but this evening I found the end of the fuse had mostly disintegrated. Result was no ignition warning lights, no fuel pump, no go up even though starter motor kicked over OK.
I had no indicators either.... Replaced a couple of relays and the ignition module but to no avail. Thought I'd check the fuses once more. They all looked fine but the end had all but disappeared from number 13. Swapped the fuse with another and the old girl came back to life instantly.
I replaced the engine harness a while back with one I made up...could not get the original for love nor money. This was an easier operation than I thought. I've had many escapades with this vehicle, that's why I love it so.
It's never broken down more than a couple of kilometers from home in ten years and 150,000K's of motoring.
Ovlov is a 1983 240 Wagon with B23 powerplant and four speed auto.
Old Mar 9, 2011 | 01:54 AM
razzledog's Avatar
Default Beware of cheap ceramic fuses!
This tiny item can stop a ton and a half of Swedish steel...
Old Mar 10, 2011 | 12:19 AM
SlickNerd's Avatar
I like this post...it sort of makes me feel stupid. I just remembered that I have a fuse 13 that I need to check in my '82....whoops.
Old Mar 13, 2011 | 01:41 AM
razzledog's Avatar
Fuse 13 is aptly named....
razzledog
Mar 8, 2011 06:10 AM
jgc
Nov 11, 2009 07:19 PM
professor talksalot
Apr 1, 2009 08:31 PM
ciapek
Jul 17, 2008 05:50 PM
