Chronic Gas Consumption
Old 03-06-2012, 06:44 PM
Be careful putting the plugs back in. Use the extension and start them in by hand and tighten them about 1/8 turn once they are snug.
  #22
Old 03-07-2012, 06:13 AM
Ok, this morning I set out to get the worse mpg on my way to "thirty 3". The route is 3.6 miles and through 3 neighborhoods as bad as a bike trail. I believe there is 7 speed humps/bumps, some of which cause me to slow down to 15 mph or less. I was hitting 45 mph between bumps, hitting around 4,500 or better at times. Verdict is that I still got 13.8 mpg. All that to say this, Something have to be bad wrong to get under 15 mpg.
I was driving a Saturn one day and was getting about 3 mpg. Pulled over to find gas pumping out behind the left / front tire.
  #23
Old 03-07-2012, 08:57 AM
Swedllander's Avatar
Originally Posted by Jakeness
Thanks act, I'll check all of those as soon as I can.
ETA: how would I test for a dragging brake caliper?
Very quick but not very accurate way to check will be:
1.Park on some incline, go to neutral with foot on brake. Release he brake, if car moves...'freely' to wards down hill, the callipers are not dragging, if the incline/slop is minor.
2.The hanging callipers will 'heat' the wheel hub, but it needs checking 'differential between front two, or rear two...provided one of the rear is NOT hanging..to remain at ambient ralative to the other which "IS".
But proper way is to jack one wheel free of the ground....of course but to go thru all four does take good effort and time compared to quick dirty check..as explained in 1. and 2...above
I've seen on my cars NOT driven for long, and then the damn drag, because of load, also 'delays' the shift of auto transmission....another indicator. In some case sthe hanging Cal heated the rortor and hub and also the barke cyl and then fluid somuch that the boiling fluid comes back to master cyl and ruins it...which 'HOLDS' pressure, as disc brakes ve NO return spring..
Have gone thru it twice....the local mech always wants to "REBUILD" the callipers..and not think of the ruined master...damaging the slaves 'again' !
  #24
Old 03-07-2012, 01:28 PM
I struggle to maintain 8mpg on my '95 940 turbo wagon. I've been driving as economically as I possibly can for the past few months and nothing has changed, so I'm assuming this has to be a mechanical problem. Any thoughts on what might need to be checked out?
Ok, so by NOW, have w improved any..or at least confirmed any or found any...THING, I mean ????
  #25
Old 03-08-2012, 09:24 AM
How does that compare to highway keeping @60 mph, and going for a length of at least 30 miles to see if you indeed you need 1.5g or 2.0 g to refill to 'same' level to ''spill'...?
Local driving for short distances can be disastrous...particularly if you ve a traffic light, that has been programmed to not to change...if it detects you as a driver..LOL , while idling...but changes as soon as u shut the engine off !!
  #26
Old 03-11-2012, 05:15 PM
Jakeness's Avatar
Turns out I have a dragging brake caliper! And better yet, the same wheel with the dragging brake is also massively out of alignment.
I'd like to thank all of you for taking time out of your day to help me out here I really appreciate it.
pissedoff
09-30-2007 05:15 PM
cserrano
08-20-2007 11:56 PM
Buck
06-11-2006 12:36 PM
gent
08-27-2005 03:27 PM
martyne
01-19-2005 01:03 PM
Quick Reply: Chronic Gas Consumption
