"Clinking"
Old Mar 26, 2011 | 01:33 PM
zloetakoe's Avatar
Default "Clinking"
Last issue to think about for the day. What could be causing a clear CLINK every so often from engine compartment. I've never heard it until recently when I was letting the car idle and standing over the engine. Almost sounds like a box wrench is loose and every once in a while taps against something. It's not consistent, sometimes a full minutes would go by without hearing it, then it would clink once, then it would happen 15 seconds later 2 or three times within 10 seconds. ??? I'm stumped, hoping it's nothing serious because it is very audible and clear with the hood up. Like I said, it would be like holding a wrench and bumping it against some metal.
Old Mar 26, 2011 | 02:51 PM
swiftjustice44's Avatar
Hmm...exhaust cooling and contracting?
Old Mar 27, 2011 | 08:35 PM
Titan Joe's Avatar
I would agree with swift, but I have on question: do you hear this after you shut off the car, or can you hear it while the car is running. When the car is just shut off, this sounds like the normal cooling noise swift was describing.
Old Mar 27, 2011 | 08:51 PM
zloetakoe's Avatar
Ha, no. This noise is when the car is running and it's similar to but much more noticeable than the cooling of the exhaust (by noticeable I mean louder). I'm wondering what could be loose somewhere. The car's AC was very loosely mounted (little to no tension) when I checked the belts and was missing the rear AC mounting bolt. Who knows what else is loose under the hood that I just haven't noticed yet.
Engine Mounts maybe? I'm planning on tackling those soon along with the Tranny mount. Good times.
Old Mar 28, 2011 | 01:18 AM
Titan Joe's Avatar
Hmmm, that's strange.
Old Mar 30, 2011 | 10:31 PM
NCVOLVO940's Avatar
accessory mount bushing maybe?
are the belts "jumping" any when the clinking noise happens?
Old Mar 30, 2011 | 11:02 PM
zloetakoe's Avatar
hmmm... good suggestion. I'll check that out next time I've got the hood open. It doesn't affect driving, or the way it runs at all, so I'm just driving it and trying to not worry about it too much.
Ripkord
Dec 28, 2018 08:28 AM
tv23
Feb 24, 2011 08:23 AM
Cyclenby
Feb 14, 2011 11:02 AM
tklatt2
Jun 15, 2009 09:44 AM
Platinum52
Apr 17, 2008 06:10 AM
