Cooling fan clutch question
Old Dec 24, 2013 | 09:39 AM
Pugluvr's Avatar
Default Cooling fan clutch question
1990 240DL Wagon 170k miles
Is it possible that a failing cooling fan clutch could make a sound like a failing bearing (a squeaking, rubbing sound)? I hear that sound coming from the front of the engine at the midline. I hear no unusual noises when listening to a piece of wood touched to the timing belt cover, alternator and power steering pump. Suggestions?
Old Dec 24, 2013 | 02:16 PM
lev's Avatar
lev
It's possible but I'd look at the belts first--they sometimes come up with all kinds of weird noises; I had a belt once that sounded like a rod knock! Best way to eliminate the belts is to run some soap along the edge as the car is idling to see if the noise changes. Of course be careful doing that procedure around all moving parts!
Old Jan 2, 2014 | 05:37 PM
Pugluvr's Avatar
Yeah, I guess it was a noisy belt, but like you wrote, it was a weird noise that I would not have guessed as coming from a belt. A few spurts of belt dressing seems to have quieted things back to normal. Thanks.
norasaint
Sep 20, 2012 12:53 AM
act1292
Aug 14, 2012 08:10 PM
anotherskait@yahoo.com
May 2, 2009 09:29 PM
elouadj
Jun 25, 2008 07:00 PM
