Crank no start
Old Nov 18, 2023 | 04:24 PM
optjr's Avatar
Default Crank no start
A little back story first, I blew the head gasket at a temperature close to around 240⁰c, and warped the top, and got water in the oil so I took it apart and got it resurfaced and lett it stay apart for probably a month. and now I'm here, I've re built it, drained it, and changed the oil and filter, and now it won't start. I've checked the timing and that's correct, I've checked for spark and that's good. I dubble checked if the plug wires was correct, and I got compretion, I've got fuel to the fuel rail the only thing I didn't check is if the fuel injectors work. but I haven't messed with them and I marked where they came from so they're on right so I'm out of ideas for now. if anybody has had or have the same problem could you help me out here? it's a Volvo 940 form 95 with the b230fk engine if that helps.
Tonyb230f
Jun 24, 2023 12:53 AM
Trollo665
May 25, 2023 11:02 AM
ctullar
Apr 29, 2013 08:05 AM
cmarino
Nov 18, 2012 09:36 PM
Chebucto
Sep 16, 2009 07:46 PM
