Definitive Bleed Order for ABS cars and troubleshooting
Old Mar 18, 2024 | 06:07 AM
ChristianWestDK's Avatar
Default Definitive Bleed Order for ABS cars and troubleshooting
Hey there!
I have a 1991 240 wagon equipped with ABS, which is long overdue for a brake service, and am unable to find a definitive bleed ordering for the wheels. As I understand each caliper only have one bleed screw/valve.
From googling I have found conflicting information: Some say I should bleed furthest away from the ABS box / pump and then move closer, ie. Right Rear (RR), Left Rear (LR), Right Front (RF), and finally Left Front (LF).
This link on turbobricks says LR, RR, LF, RF.
What is the correct ordering?
Furthermore, I am almost certain that something in the ABS circuit has failed as I have not experienced the shaking brake pedal, even when driving on solid ice. My car is not equipped with the diagnostics system for the ABS. The ABS box / pump is not leaking as far as I can see. Where should I start troubleshooting? I heard that some cars have the ABS computer under the front seat and there is a fuse somewhere...
Kind regards
Chris
dougrock
Jan 11, 2023 03:08 PM
brianb
Nov 14, 2010 11:00 AM
cbevis
Jan 23, 2010 08:55 PM
robohopar
Sep 27, 2007 11:37 AM
Volvo_User
Oct 25, 2003 02:58 AM
