distributor wont rotate cant adjust timing
Old Mar 9, 2014 | 02:24 PM
mikde's Avatar
Default distributor wont rotate cant adjust timing
1980 242gt b21
I'm trying to adjust the timing and the distr will not turn even with the hold down bolt removed. i have spayed PB blaster around the base and tapped on the distr with a hammer. It wont budge. any ideas how not to break the distributor.
Old Mar 9, 2014 | 05:23 PM
Titan Joe's Avatar
A bigger hammer. I was going to suggest everything you have already done. Have you let it soak with the blaster over night? Is there only one hold down bolt? My 740 has two, but the distributor is different from a 240 and on the back of head.
Old Mar 9, 2014 | 05:39 PM
mikde's Avatar
Default stuck distributor
it has soaking for over a week. I tried heat, no good
But the bigger hammer worked. I used a pipe wrench, the distributor died but I found a spair just in case.
Old Mar 9, 2014 | 07:31 PM
So were you able to get it free with the pipe wrench or the hammer ??
Old Mar 9, 2014 | 07:49 PM
mikde's Avatar
Default distributor
small pipe wrench and 1/2hr of twisting back and forth
Old Mar 9, 2014 | 07:57 PM
Were you able to save the distributor ??
Once you sand or scrape it clean, good time to coat the heck out of it with anti-seize !!
Old Mar 9, 2014 | 08:02 PM
mikde's Avatar
Default distributor
nope doa, but anti seize is already applied to the spare distributor
qstyle
Jul 25, 2010 09:51 AM
im4rcn
Mar 10, 2010 10:55 AM
ludeless
Jun 22, 2008 08:39 PM
rationull
Apr 3, 2007 01:18 AM
HotCoil
Mar 17, 2007 08:55 PM
