Diving into Dash: Suggestions for Additional Items to Check/Replace?
Will be making the nasty dive into the dash to replace the blower motor, resistor, blade wheels, and switch. Does anyone have any suggestions for other items I ought to check/replace while I have the dash apart?
Thanks!
Thanks!
if any connections look corroded, clean them up.
inspect the heater core, those can fail eventually (especially if the coolant changes are neglected), and its a lot easier to replace when you're already in there.
check the conditions of the vacuum spagetti lines that activate the air vents.
Mreuter2
Nov 9, 2013 08:54 PM
GoVolvoParts
Feb 12, 2013 03:03 PM
