Door lock Problems
Old Oct 14, 2007 | 08:58 AM
firstonraceday's Avatar
Default Door lock Problems
I have a 91 740 non turbo. the problme that i have is ya know how the doors only lock from the outside, well now when i go to lock the car it will only lock the drivers door. its not like it used to be when i'd lock the drivers door and all the other doors would lock/ unlock and the same with the trunk. so now i have no way of getting into my trunk and this stinks. does anybody know how to fix this?
thanks erik
Old Oct 14, 2007 | 09:01 AM
Default RE: Door lock Problems
Is the fuse for the door locks blown?
The key should also unlock the trunk as well.
Old Oct 19, 2007 | 05:40 PM
is there another fuse block that I am missing, the only one i know of is behind the shifter. and for some reason my key does not unlock the trunk.
but I dont think I need to be looking for a fuse because it seems when I would lock/unlock the car the rest would do the same, seemed to be mechanical. my car can only be locked and unlocked from the outside, there are no window switches for locking and unlocking.
does this help any?
Old Oct 19, 2007 | 06:49 PM
ccslaxer44's Avatar
I had the same problem with my '90 740, turns out some of the wires were broken between the door and the body. You might wanna follow them and see if they're intact.
Old Oct 20, 2007 | 12:04 AM
tripleb's Avatar
First of all is the fuse for the locks, but then there is a switch in the door lock assembly that may be bad. And then the wiring.
Old Nov 4, 2007 | 08:51 PM
ccslaxer44- called it one of the wires is almost fully broken. problem fixed. thanks again guys.
erik
Lgbpop
May 26, 2021 03:34 PM
qcvol
Jun 17, 2013 09:55 PM
crgolf
Feb 10, 2013 12:43 PM
rcvolvo
Jun 3, 2012 02:25 PM
dkbmx8485
Oct 19, 2007 12:43 PM
