driveablity problem UPDATE!!!
Old Nov 16, 2007 | 09:42 PM
volksnut's Avatar
Default driveablity problem UPDATE!!!
93 Volvo 240....on take off or when idling, when you give it gas it has a slight to very noticeable hesatation, if you move the pedal down slow sometimes it doesn't respond til 1/4 pedal, doesn't do it everytime but does have a miss, runs fine when driving at speed..you think fuel related (i.e. fuel filter or pump?)
Old Nov 16, 2007 | 10:06 PM
Default RE: driveablity problem
Has the throttle body been cleaned lately?
Old Nov 16, 2007 | 10:28 PM
volksnut's Avatar
no it has not....
Old Nov 16, 2007 | 10:34 PM
I would try that first.
I have also seen a bad coil have similiar symptons as well.
Old Nov 17, 2007 | 12:50 AM
tripleb's Avatar
Try checking for codes.
I have seen the MAF sensor cause this very problem.
The MAF sensor has a direct impact on the air/fuel mixture and the ignition timing, so it can cause all kinds of problems, and they often fail.
Old Nov 17, 2007 | 11:35 AM
volksnut's Avatar
well thanks guys...No check engine light so checked codes, no codes either....then I checked and cleaned the throttle body (YUCK!) and also pulled the MAF sensor and cleaned it also, drives like a champ now thanks again
Old Nov 17, 2007 | 02:10 PM
volksnut's Avatar
well a quick update, daughter drove it later on today a reported it still lunging forward, kind of like it hesitates then shoots forwards and takes off? Any other ideas...withhout some codes I'm in the "dark"
Old Nov 17, 2007 | 02:46 PM
I still think it might be the coil and maybe even the computer.
Old Nov 30, 2007 | 05:25 PM
volksnut's Avatar
okay last night my daughter said the engine light came on....can you look at it tomorrow morning...yeah at 6:15 before I go to work...well yeah I did and ran a diagnostic check...said MAF sensor...told her drive it and and I'll look at it when I get home...when I got home she said it was running bad...I checked connector and now it's reading O2 sensor....what do you think? change the O2 sensor???
Old Nov 30, 2007 | 06:21 PM
tripleb's Avatar
What specific codes are you getting?
The O2 sensor and MAF sensor have a kind of "give and take" relationship. They both can have an effect on the other, so it can be hard to tell which is actually bad.
B
Old Nov 30, 2007 | 07:04 PM
volksnut's Avatar
221 and 231
Old Dec 1, 2007 | 03:51 AM
tripleb's Avatar
I would guess the MAF sensor is bad before the 02 sensor, with the codes and drivability issues you are having. I'd bet your thermostatic air flap in the air cleaner is stuck open to the heat stove pipe too. If you do replace the MAF, or anything else, make sure you pull the fuse for a minute to the ECM before starting the car.
B
Old Dec 5, 2007 | 03:47 PM
volksnut's Avatar
well today it finally started doing something different, only at idle...it surges, I would say 2 to 3 hundred rpm up and down, until you put it in gear it will stop, but in neutral it will keep surging til you touch the gas....any clues, still has the 02 sensor code light lit
Old Dec 5, 2007 | 06:52 PM
Throttle dirty?
Old Dec 5, 2007 | 07:06 PM
volksnut's Avatar
the throttle body was dirty til I cleaned it...but it was real dirty, like I said it just started doing this and shows a O2 sensor code, any ideas on the idle valve, I believe that's what it's called, below the intake...could this part have anything relation to this problem?
Old Dec 5, 2007 | 07:08 PM
Possiblelthe idle motor is bad.
JohnTheodore
Nov 11, 2007 08:17 PM
slang925
Aug 7, 2007 06:46 PM
mike222
Mar 10, 2006 07:31 AM
mike222
Dec 4, 2005 01:32 PM
