driver side power steering leaking oil
Old Oct 13, 2008 | 12:42 PM
tringa's Avatar
Default driver side power steering leaking oil
hi to all, i have recently purchased a 92 volvo 240 wagon. i love the car and has been driving well so far. i noticed a leak on the driver side, it seems to be coming out from the boot cam rack (not sure this is the proper terminology). it leaks quite a lot and i had to add oil otherwise the steering will start to make noise. how can i try to determine what the problem is? thank you in advance for any help!
Old Oct 13, 2008 | 12:47 PM
Default RE: driver side power steering leaking oil
Most likely it is the rack leaking and the rack needs to be replaced.
Old Oct 13, 2008 | 12:57 PM
tringa's Avatar
thanks a lot tech. is this something i can attempt myself or is too complex and needs specials tools to do it? i have seen on the web is possible to find parts at a reasonable price. Is the part that i need the "Steering rod (tie rod), for CAM rack" found this steering
Old Oct 13, 2008 | 01:23 PM
You should be able to handle it but it will need an alignment as soon as you get done.
You will need what they call a steering rack and pinion or a steering gear.
This is what you need
http://www.fcpgroton.com/product-exe...ategory_id/179
Old Oct 13, 2008 | 02:57 PM
tringa's Avatar
thank you for the answer and link tech. Appreciated. I see, need to replace the entire thing, it looks complex and expensive if i can't find a rebuilt one. i will start organize the job and source the part. thanks a lot again!
xeneizes
Feb 19, 2013 09:56 AM
BillLisa
Jun 27, 2011 11:29 AM
LovemyS80
May 28, 2011 04:30 PM
epgiles
Apr 6, 2009 06:59 AM
autoxray
Jul 6, 2008 12:18 AM
