Driveshaft support bearing
Old Jun 9, 2010 | 03:05 PM
daver80's Avatar
Default Driveshaft support bearing
89 240DL wagon, 220k - Getting an annoying shake shake- tires rebalanced several times. Mechanic said center driveshaft bearings are worn and loose. I see the part on FPC, how big a job is replacement of these. Also said the tranny mount was worn, but that looks pretty easy. Thanks! Dave
Old Jun 9, 2010 | 03:29 PM
adub96's Avatar
Kind of a pain in the *** cus usually everything is rusted and funky and doesn't come apart easy.
Old Nov 6, 2010 | 05:36 PM
bailey3355's Avatar
Does it require any special tools?
Old Nov 6, 2010 | 05:37 PM
bailey3355's Avatar
Old Nov 7, 2010 | 08:11 AM
Rusty van Pelt's Avatar
http://www.volvoclub.org.uk/faq/Driv...rtBearingNoise
Old Nov 7, 2010 | 12:50 PM
TIPSP's Avatar
Got Boost?
The center support is not that bad to replace. just make sure you mark the postion of the flanges so you put it back together the exact same way you took it off.
the trans bushing is pretty simple. I opened up the hole in the crossmember, becuase the sockets I had would not fit in the hole they provided.
MoneypitC70
2001-2013 model year XC70
Oct 26, 2014 08:37 PM
titanac
1998-2000 model year V70
Jul 16, 2012 06:03 PM
cichy1012
Oct 10, 2011 05:12 PM
daren1
Apr 19, 2009 03:41 PM
xallenx
May 14, 2008 01:41 PM
