Dropping out of Cruise Control
The cruise control on my '93 940 works most of the time. Occasionally if we hit a bump, it will drop out of cruise and will not re-engage. Turning it off and then back on a while later will sometimes cause it to re-engage. Any tips as to why this happens? TD
The switch is on top of the brake pedal under the dash, black plastic, metal clip. You have to turn it to where it's harder to activate and not open when the pedal is slightly moved... You can do this just by turning it while in place--no need to take it out. You can test its function by keeping the pedal up with your foot, not allowing it to disengage the switch by going down. Manual cars have two switches, one for the brake, the other for the clutch.
