Electrical Modifications
Old Sep 15, 2013 | 05:09 PM
piv15's Avatar
Default Electrical Modifications
I'm thinking of modifying the system of the delayed dome light. First of all, I'd like to make it so that if any door is opened, then it will delay the light. After studying some wiring diagrams, it seems it shouldn't be too difficult. Any pointers you could give on this? Eventually I also intend to install an L.E.D lighting kit for the foot wells, and possibly somehow make the dome light an L.E.D.
Old Sep 15, 2013 | 06:21 PM
I put LED dome lights in both our volvos, using lights from www.superbriteleds.com ...
specifically, this lamp is a drop in replacement for both front and rear dome lights in my 740 wagon. 6451 LED Bulb - 6 SMD LED Festoon | Festoon Base Bulbs | LED Car Bulbs | Super Bright LEDs
because I'm an amateur astronomer, I put a red one in my wagon's rear warm-white in the front. much MUCH brighter than the stock lights.
Old Sep 15, 2013 | 09:35 PM
piv15's Avatar
Interesting indeed! I bet it would be a lot nicer than the stock light. Still, think it'd be a difficult task to make it to where the light would do its delay with all other doors?
Old Sep 15, 2013 | 09:52 PM
haven't had the energy to look up the diagrams yet.
Old Sep 15, 2013 | 10:50 PM
piv15's Avatar
Well, the timer relay is somewhere under the dash, (either under the instrument cluster, or the plastic side panel) on the driver's side. I think the only challenging parts would be routing all the wires from the door switches to the relay.
Old Sep 15, 2013 | 11:17 PM
on my 740, its built into the dome light fixture
S70driver
May 24, 2013 12:03 AM
GMad
May 23, 2008 01:00 AM
Escilade2volvo780
Apr 14, 2008 08:51 AM
conceptmuscle
Mar 12, 2008 09:07 AM
DavidSchneider
Jul 7, 2005 01:41 PM
