Engine stalls after it is warm
Old Nov 14, 2007 | 11:46 AM
rgraves1's Avatar
Default Engine stalls after it is warm
I just bought a 90 240dl for my daughter, it ran perfect at idle and around the block several times, but I drove it about 50 miles on the interstate all was fine. When I got to the top of the off ramp it stalled, then it stalled at every stop until I got home...Please help!!!
Old Nov 19, 2007 | 06:46 PM
rgraves1's Avatar
Default RE: Engine stalls after it is warm
It is fixed!!!! It was throwing a 214 code in position 6...crank speed sensor...quick trip to the junk yard $5 later purrs like a kitten
Old Nov 19, 2007 | 10:29 PM
tripleb's Avatar
If I had one for my daughter, I would replace..
Fuel pump relay, they have a high failure rate, and will leave you stranded.
Thermostat for the air cleaner, they stick open and burn out the MAF sensor, causing starting problems and stalling.
If it has a 25 amp fuse by the LF fender, replace the fuse and holder, they corrode and cause no start problems.
Just a few insurance repairs, good luck!
B
Old Nov 20, 2007 | 09:35 AM
rgraves1's Avatar
Thanks a bunch!!!
Old Nov 21, 2007 | 08:53 AM
rgraves1's Avatar
White or green relay?
Old Nov 21, 2007 | 06:26 PM
tripleb's Avatar
It is a white relay, and it is behind the glove box, you can access it by removing the under dash panel, it is cliped to the firewall.
B
Squirt
Dec 29, 2020 02:53 PM
triggerman
Jan 23, 2011 02:13 PM
philipfred
Jul 13, 2010 01:57 AM
tomalott
Feb 13, 2009 11:59 PM
Subbuilder
Jun 22, 2008 03:27 PM
