Stalls (no gas) when not warm
Old Jun 22, 2008 | 01:13 PM
Subbuilder's Avatar
Default Stalls (no gas) when not warm
I have a 93 940 wagon with Regina ignition. 100K runs good except for a stalling issue.
If I let car warm up to operating temp, all is okay. If I don't let it warm up, the car will stall. Usually twice. Hard time restarting. No gas. It seems to be choking itself, like no gas. RMPs do not go right to zero on stall. Already replaced air control valve which cleaned up the idle. Replaced the airbox temp sensor. Cleaned throttle body. Didn't fix it.
I'm ready for help. Any ideas.
Thank you.
Old Jun 22, 2008 | 02:34 PM
Eric J's Avatar
Default RE: Stalls (no gas) when not warm
Welcome to the forum Subbuilder.
Did you change the fuel filter? This is commonly overlooked and will produce the same symtoms.
Old Jun 22, 2008 | 03:27 PM
Subbuilder's Avatar
Thanks Eric.
Yes I did. Plugs, wires, filters, first and the IAC valve relieved my jumpy idle.
No codes. No check engine light.
Now I know more about the Regina ignition than I thought I ever would! May still not be enough though.
Seeing that it is consistantly stalling when I don't let it warm up and running fine when I do,
I think I have narrowed down the symptom somewhat.
Squirt
Dec 29, 2020 02:53 PM
triggerman
Jan 23, 2011 02:13 PM
philipfred
Jul 13, 2010 01:57 AM
tomalott
Feb 13, 2009 11:59 PM
rgraves1
Nov 21, 2007 06:26 PM
