Engine temp issues
Old 06-26-2022, 07:06 PM
ethanisloud's Avatar
Default Engine temp issues
I have an 87', 245 with engine temp control issues; it will operate above normal in routine driving, and almost into the red in traffic. The thermostat & temp control sensor have been replaced & the water pump bearing sounds good. The system was flushed & new hoses installed less than 2,000 miles.
There are also issues with the instrument panel gages going haywire. The differential speed sensor was changed out about 1,000 miles ago & the speedometer began work (but the odometer did not). Then the temp gage began reading hot & the speedometer pegs to 120mph (& stays there) when the car is started.
Does anyone have any thoughts?
Old 06-26-2022, 08:40 PM
lev's Avatar
lev
lev is offline
Make sure the engine is indeed hot, use an infrared temp gauge. Sounds like you have instrument pod issues.
Old 06-26-2022, 08:41 PM
A common problem my shop fixed many, many times is a partially clogged radiator that will overheat in low speeds and be better with more air flow. A new radiator, or rodding a copper radiator solves it. (you can't really rod an aluminum radiator)
And
Are you aware of the temp compensation board problems in 1986+ 240's? Where the temp gauge is not accurate due to connection problems on the temp comp board? Here's a way to get true temp reading.
240 Temp Faker
Your speedo is just probably bad. There's really no connection between the two - if fact the gas and fuel gauge have their own voltage regulator on the back of the cluster to make them more accurate.
960cd
05-12-2022 10:04 AM
blackbrick
05-07-2011 01:46 PM
S70driver
02-04-2010 06:07 AM
bgeacook
08-13-2009 12:43 PM
edgoss
10-17-2006 08:53 PM
Quick Reply: Engine temp issues
