Failed CA smog due to incorrect TDC or timing
Old Jun 16, 2010 | 07:55 PM
redbottle's Avatar
Default Failed CA smog due to incorrect TDC or timing
First attempt to smog the TDC Read: 12 BTCD
Second attempt to smog the TDC Read: 31 BTCD
NO (PPM) was
1st: 3827 MAX @ 15MPH 2992 @ 25MPH
2nd: 4134 MAX @ 15MPH 3171 @ 24MPH very low on fuel
new plugs
distributor cap & rotor
wires
O2 sensor
cat converter (190 freaking dollars)
you know I think I installed a later model fuel pressure regulator?
and 89 fuel injectors new.
I passed all else nicely
any ideas on the emissions deal here?
Old Jun 17, 2010 | 10:30 AM
bubba240's Avatar
Do you have a timing light? I could be the crank pulley ... read the fault description here ...
http://www.ipdusa.com/Volvo-200/Engi...9-258-465-441/
Old Jun 17, 2010 | 11:01 AM
redbottle's Avatar
e ignition timing marks will no longer line up and when using a timing light you will see the timing marks slowly rotating as the outer pulley slips"
I'LL BE DAM...! this sounds correct....I did the heads not too long ago and had a funny feeling about the crank pulley....I don't recall torquing the nut?
GRATZE BANBINO
Old Jun 17, 2010 | 11:14 AM
bubba240's Avatar
for the nut ... tightening torque stage one is 44 lbs., stage 2 is another 60 degrees. They check the timing during the test?
Old Jun 18, 2010 | 12:59 AM
redbottle's Avatar
60 degrees? 3/4 turn a little less right?
Old May 15, 2011 | 11:24 AM
1staveguero's Avatar
Crankshaft Pulley Vibration Damper
Thanks for that link! I'm having the same problem; failed the CA smog test because the technician wasn't able to time the engine on my '86 240. I lined up the TDC marks and the #1 piston was not at the top. I ordered another pulley so I'm hoping it will solve this problem.
The other problem was that the gas tank won't hold pressure but I'll make a new thread for that.
tassadar30
Apr 23, 2007 11:07 AM
HelgaTheS80
Feb 24, 2007 12:57 PM
joanvito
Sep 28, 2006 09:19 PM
dynomac
Sep 24, 2006 12:12 AM
tassadar30
Jun 22, 2004 01:16 AM
