fitting volvo 740 turbo
Old Jan 4, 2009 | 03:55 PM
volvo740kid's Avatar
Default fitting volvo 740 turbo
hi im new to this site,i was just wondering how hard it is to fit a volvo turbo to a volvo 740 se 2.0
Old Jan 4, 2009 | 05:05 PM
tedv's Avatar
Default RE: fitting volvo 740 turbo
Pretty hard. Better to sell the nonturbo and buy a turbo, will cost you much less.
Old Jan 7, 2009 | 12:50 PM
could i do and engine swap using a volvo 940 2.0 turbo engine?
Old Jan 7, 2009 | 02:28 PM
TIPSP's Avatar
Got Boost?
You will have to get the ECU/ICU from the turbo model and wire harness, as well as new exhaust, IC and IC Pipes....etc.
Like tedv said it would be cheaper to get a turbo model.
Old Jan 7, 2009 | 03:47 PM
the 740 turbos are super rare tho iv been looking for about six mouths and not found 1
Old Jan 7, 2009 | 04:24 PM
TIPSP's Avatar
Got Boost?
Yeah, the740 models are becoming harder and harder to find. I have only seen a few for sale in Cali (USA).
If youcan get the 940 motor for a good price then I would just swap them, but you will need the supporting ECU/ICU....etc.
Well if you do want to turbo it. you will need to get these things (list from s70driver).
1. Turbo 2. Downpipe 3. Catback 4. Injectors 5. Charge pipes 6. Turbo hoses 7. Vacuum lines 8. Hose clamps 9. Intercooler
10. MOST IMPORTANTLY, a major ECU tune. And I am not talking about IPD, RICA, BSR, etc... I am talking dyno tuning to properly get the right tune.
11. Drill hole in the block for oil return line. 12. ETC...
But if you do this, you wont be able to run that high of boost, unless you change the CR to ~8 instead of your CR 10.
Old Jan 7, 2009 | 04:26 PM
my volvo is a 740 2.0 se and i would like it turbocharged money is not an object,what parts would i need.
Old Jan 7, 2009 | 04:28 PM
would a volvo dealer do all the fitting of turbos or would i have to go to a tuning shop.
Old Jan 7, 2009 | 05:01 PM
TIPSP's Avatar
Got Boost?
You would have to find a shop to do it, unless you know how to. Depending on theshop, they should be able to doa custom step for you. Expect to pay$3-$10,000+.
If you want to do it yourself, check this out: http://www.ipdusa.com/tm-18it is for a 240, but it ispretty muchthe same idea.
What you will need:
1. Turbo
2. Downpipe
3. Catback
4. Turbo Injectors
5. Intercooler
6.Exhaust manifold
7. Hi-Tuning.com chips for your ECU/ICU to run your +T setup
8. Drill a hole in the block for oil return line
there might be more things but I cant think of them right now.
Old Jan 8, 2009 | 12:00 AM
RED MOFO's Avatar
Didnt Turbo Models also come with a different Rear Gear for more low end until the Turbo Spooled up?
Also, You'll need the intire Turbo intake hose setup, like that huge filter box, the hose from it to the turbo, with the MAFS in it.
I got my 1990 740Turbo for 250 dollars, 149,000 original miles, had a totally cooked turbo and the interior was trashed, both caused by a careless teenaged girl owner. Put a new turbo on it, had the entire interior redone, new Moon Roof, and painted it, and Darned if it isnt a slick ride.
Old Jan 8, 2009 | 02:39 PM
theres a volvo 740 glt 2.3 16v auto local for sale,would this fit in my 740 se manual.
many thanks
Old Jan 8, 2009 | 03:05 PM
TIPSP's Avatar
Got Boost?
Any of the B23..enginesshould mount to any of theAW/ZF transmissions.
I am not that familar with the UK version, so Dosethat 740glt have a turbo (is it a B234F or a B234FT)?
Old Jan 9, 2009 | 11:44 AM
no,its a straight 2.3 16v
Old Jan 9, 2009 | 12:11 PM
TIPSP's Avatar
Got Boost?
It should mount to your trans.
If you get that car or a turbo model, it might be easier to swap the transmission instead of swaping themotor to your SE.
You will have to use the clutch from a turbo model if you go turbo.
You should check out turbobricks for they mess with this stuff all the time.
Old Jan 12, 2009 | 02:17 PM
iv found a volvo 960 2922cc auto real colse to me would this fit in my manual 740 to the gearbox ok and mountings.many thanks
Old Jan 12, 2009 | 04:57 PM
TIPSP's Avatar
Got Boost?
That is B6304S (straight six), I think, and I dont know if that will work.
Old Apr 28, 2009 | 07:39 PM
  #17
drummerdude08's Avatar
I have an '88 740 turbo. it's got overdrive problems and a crack in the exhaust manifold, but its still a solid ride. family's been driving it since new. almost 280k miles, but whats wrong are the only things not replaced. would you be interested?
Old Apr 30, 2009 | 04:55 AM
  #18
Typhoon's Avatar
The only really smart way to do a swap like this is to buy a donor car, otherwise you'll forever be chasing up this and that, brackets etc that you need but don;t have a clue what they look like.
The problem with buying a donor car is, why not just fix teh donor car instead of pouring money into teh other?
Seriously, drive what you have now, save your money, be patient (I know that's hard when you're young) and buy the next turbo you see.
Regards, Andrew.
940kev
Jul 21, 2008 03:14 AM
montysano
Apr 18, 2008 01:08 PM
dave88_850
Jul 14, 2007 01:47 PM
mutiger2000s70
Jun 17, 2007 07:18 AM
crazynlazycolombian
Jun 4, 2006 08:48 PM
