Fixing Compressed bumper on 1988 Volvo 240
Old Jun 21, 2009 | 09:39 PM
brooklynaut's Avatar
Default Fixing Compressed bumper on 1988 Volvo 240
Hi there -
Does anyone have any suggestions about how to pull out the bumper on a 1988 Volvo 240 DL wagon? I'm sure it's pretty straightforward, but I'm not sure.
Any suggestions?
I'm also trying to fix a lot of the loose trim around the car. Any suggestions for epoxy or anything else?
Thanks!
Keith
Old Jun 22, 2009 | 07:17 AM
adub96's Avatar
If they are stuck in that probably means they are bad. I would go to a junk yard and pull a set off a car sitting there and replace them. For safety reasons.
Old Jun 22, 2009 | 01:39 PM
blue goose's Avatar
3M Trim Adhesive works good.
Old Jun 22, 2009 | 02:14 PM
Default Replacing Bumpers
Okay - so any suggestions as to how to replace a bumper?
I am just handy enough to get this done by myself, but suggestions and tips are very welcome.
Old Jun 22, 2009 | 05:20 PM
tedv's Avatar
What is "compressed"? The shocks or the plastic?
Old Jun 23, 2009 | 05:51 AM
The whole bumper is compressed on one side on both the front and the back bumper. It's not really squashed in all the way, just a few inches. Not sure what kind of accidents the previous owner got into, but there are minor bonks all around this car.
So - the rear bumper, for example, is halfway compressed on the passenger's side. The front bumper is also slightly compressed on the passenger's side. In addition, the light assembly and the front grill are a bit out of line. I think that I can fix them and get them put back into place, tho'.
Old Jun 23, 2009 | 08:49 AM
adub96's Avatar
another, more dangerous option, you can drill a hole in both shocks til the gas expels, then put the car against a building and push the bumpers in using the motor. Then you'll have that tucked Bumper look that was popular about 10 years ago.
Old Jun 23, 2009 | 09:00 AM
tedv's Avatar
The "shocks" that compress are not supposed to be decompressed even though I have seen it done which results in their reduced efficiency. I'd go to a junkyard and get them there for cheap-they are plentiful in just about any "pull-your-own-part".
Old Jun 23, 2009 | 09:56 AM
adub96's Avatar
reduced efficiency? They flat out don't work when compressed. Hence why I said dangerous option.
vlcmskater11
Jan 17, 2009 08:47 AM
shahid_zaman
Jun 21, 2008 08:44 PM
shahid_zaman
Engine & Internal
Jun 21, 2008 07:58 PM
shadowlord
Apr 8, 2008 09:16 PM
fignozzle
Nov 15, 2005 12:18 AM
