Floor pans: New vs. salvaged
![Question](https://volvoforums.com/forum/images/icons/icon5.gif)
Hello! This is my very first post here...
I am the proud owner of a 1990 240 DL wagon that my wife and I got brand new as a wedding present.
30+ years and quite a bit of rust later, we are in need of a replacement floor pan. It's an expensive prospect, but even at $2000 for labor, it's worth it to keep our baby aloft.
I have a to-be-junked '84 240 sedan, whose floor pan I could salvage -- but getting it out would probably cost more than buying an aftermarket pan.
BUT -- who makes decent floor pans? Is there a difference between suppliers? I've seen them advertised for under $50, but that seems really cheap.
What should I look for (and where) in a quality floor pan?
Thanks for any advice you can offer!
have you found an after market supplier for a replacement floor plan?? if you go used, then you have the complication of getting the old pan out of the donor car, disposing of the donor car, then cleaning up/patching any flaws and rust proofing (check with a local auto paint supply company for commercial rust inhibitors). If you are lucky enough to find an after market, the only concern I'd have is fit where you may need to trim etc. Don't think quality is an issue since you'd still want to rust proof the new part just the same.
i believe someone said these guys put out good product
https://raybuck.com/panels/volvo/?qu...&fwp_model=240
haven't a clue! on the other hand i guess it may be worth the small risk to order one and see. that's the part you need right?
I agree on buying quality for mechanical parts (like the cited window regulators) as well as rubber (ie bushings, control arms etc). For bent metal like replacement floor pans, fenders etc, there may be differences in the thickness and the quality of the steel. For exterior metal (ie fenders) fit and thickness are more of a concern than say for a floor pan but there you'd worry about longevity which requires proper rust prevention.
avanti240
11-20-2019 06:01 AM
