Need help with 76 242, sitting 15 yesrs
Old Oct 22, 2020 | 10:06 PM
Drummer's Avatar
Default Need help with 76 242, sitting 15 yesrs
Hello, helping my neighbors son to get a 242 back running. I can't see a. Big nut on the main shaft to see if the motor is free, or frozen. I'm use to Ford's, Thanks.
Old Oct 22, 2020 | 10:39 PM
lev's Avatar
lev
There should be a BIG bolt on the crank pulley, it's 24mm on the b230. Should be there on a '76 too... similar if not the same size.
Take out the spark plugs and squirt some light oil in the cylinders before turning the motor over, better wait a day... After 15 yrs, you got a lot of fun ahead.
Old Oct 23, 2020 | 07:28 AM
Originally Posted by lev
. After 15 yrs,
I wouldn't count of getting the fuel injection system to work again without a bunch of $$$$$
Old Oct 25, 2020 | 10:11 AM
Drummer's Avatar
Thanks for the help. I squirted oil in, letting it sit
Old Oct 26, 2020 | 12:15 PM
Drummer's Avatar
Is the engine rotation clockwise standing at the front of the car?
Old Oct 26, 2020 | 12:40 PM
lev's Avatar
lev
Yes, it is... Why don't you just work the starter, rotate it with battery power, with the key? Once you have oil in the cylinders it makes no difference, just easier. Just unplug the coil, doubt it will fire up anyway.
Old Oct 27, 2020 | 08:51 AM
Drummer's Avatar
Good idea, but they haven't found the key yet, it did turn by hand though.
Old Oct 27, 2020 | 09:09 AM
You can easily run the car without a key - you just can't unlock the steering column
Take the plastic cover off around the steering column ~2+ screws, take the electrical portion of the ignition switch off - 2 screws, use a screwdriver to turn the ignition switch.
For a key - Simply order a key from a Volvo dealer with the VIN number, they can cut one a have it in a couple of days or less - You may have to prove you own the car - but It will be a much easier/better result than a lock smith, or changing locks -----
Old Oct 27, 2020 | 09:49 AM
Drummer's Avatar
Thanks for all this great info. I think they will find a key.
Old Oct 28, 2020 | 09:15 PM
Drummer's Avatar
It's actually a 77 244, my next concern s getting fresh gas to the engine, I sure don't want to get gas from the tank, just to see if It will run.
Old Oct 28, 2020 | 10:38 PM
lev's Avatar
lev
15 yrs old gas? Even I won't expect that to be doable (I push the envelope)! You'll be lucky not to have to get a new tank/pump/filter--it definitely should be removed and cleaned thoroughly, rust?
Old Oct 28, 2020 | 11:49 PM
Drummer's Avatar
I want to by pass the tank, any information appreciated, till I know it runs.
Old Oct 29, 2020 | 09:17 AM
The fuel injection system on that car requires about 70 psi to work and requires a return line to the tank - So I can’t imagine how you would rig something up to use that fuel system without using the gas tank and high pressure fuel pump -
You could spray some ether into the intake to see if the ignition system works - see if you could get some cylinders to fire
I would check compression, and if over 120psi, check for a spark - then be looking for a low pressure fuel system - that engine was used in boats with a carburetor setup. As I mentioned previously that style fuel injection system does not store well - and is hard and very expensive to fix. If the timing belt is still there - don’t worry about it yet - if it breaks there is no damage, no valves will get bent.
Old Oct 29, 2020 | 09:21 AM
lev's Avatar
lev
Good idea! Never done that but I suppose just using another gas container to suck gas to the motor would work. That car should have just one pump... I'd be more concerned with the fuel injection condition after all that time. No idea what parts may have to be replaced or just cleaned...
Were you able to turn the motor?
TRFguy
Dec 25, 2014 05:22 PM
79gt
Sep 5, 2014 01:33 PM
takaia
Feb 20, 2012 08:07 AM
Maxbaby
Dec 24, 2011 09:38 PM
shop2
May 1, 2011 07:32 AM
