Fog Lights
Old Jul 19, 2006 | 02:42 AM
psychoCHIPMUNKK's Avatar
Default Fog Lights
This is probably a really stupid question, but when i flip on the fog light switch only the driver's side comes on. What's the deal? The bulb in the other side is good, but the fuse panel says there's only a fuse for the driver's side fog light?
Old Jul 19, 2006 | 02:46 AM
tupapison's Avatar
Default RE: Fog Lights
what model and year?
And if you are talking about the back fog light, then only the driver's side fog light is supposed to turn on.
Old Jul 20, 2006 | 12:04 AM
crazynlazycolombian's Avatar
i had the same problem.....check the ground wiring coming from it, mine had come loose....check that side where it is out near the wheel wells and all around.....then connect it and that should be your problem right there...lemme know it this helps
Old Jul 21, 2006 | 04:20 AM
It's a 92 240 Wagon, and the light had quite the interesting situation going on. I traced bace the wire from the passenger's side fog light all the way up to under the driver's feet, where it connected to a large wire quick connect block, and it simply had no mate on the other side. So i did the simple thing and just ran a wire over to it from the driver's side, and it worked. Simple and effective.
rspi
Jan 13, 2012 09:35 PM
SpaceMomMort
Nov 6, 2008 02:02 AM
Volvaman
Jun 26, 2008 04:16 AM
jc740T
Nov 23, 2004 10:48 PM
