Front Seat Inclination Knob- 240 DL
Old May 18, 2011 | 04:22 PM
randerson's Avatar
Default Front Seat Inclination ****- 240 DL
Was wondering how difficult it is to replace the front seat inclination ****'s for a 240. Puchased the wagon a month or so ago and it was missing the *****. Just found them today and will be shipped with the "clips."
Don't know if they just snap into place or if any special tools will be needed. Any advise?
thanks.
Old May 19, 2011 | 10:10 AM
volvoguy2323's Avatar
Banned
The locking clip is kind of tough to re-install but if it's new should not be that difficult. Make sure you line up the **** correctly and it is sitting flush and you are able to move seat forward and backward. Then install the locking clip in place. Push it in as far as you can with your hand and then I take a flat blade screwdriver or a punch and gently knock it into full locking position with a hammer. If you bend the insides of the clip, it is a pain to get it to lock properly so be gentle...good luck!
Old May 19, 2011 | 10:35 AM
zloetakoe's Avatar
I've got one of the ***** that just broke on me. Can I ask where you picked your new ones up?
Old May 19, 2011 | 08:19 PM
randerson's Avatar
I picked up 2 at Voluparts in Atlanta - Voluparts Inc. - Volvo Parts - Used and New Honest & reliable Volvo parts help since 1977. - they are used.
The clips are a bit concave so not sure which direction they should be applied. Does anyone know if there is a diagram? I know these are in short supply so would rather do it right the first time.
Thanks.
Old May 20, 2011 | 11:00 AM
Banned
Thanks.
only goes in one way...will not fit tightly other way only fall out. The bottom of "bowl" facing you...if they are used clips you may need to mess with the inside where it actually locks to the pin...just use a screwdriver and hammer and tap evenly until it locks in place for you...it is tricky but take your time you'll get it eventually...
tfwS60R
May 8, 2017 04:40 PM
dmg4
Feb 26, 2014 07:19 PM
brooklynaut
Sep 20, 2010 01:41 PM
litehwk356
Oct 4, 2008 08:20 PM
soapboxhero
Oct 13, 2007 12:25 PM
