Fuel injector seals
Old Apr 3, 2016 | 08:24 PM
Czakky's Avatar
Default Fuel injector seals
Anybody have any experience with changing fuel injector seals? I've got one leaking (#2) I see that IPD sells a kit anybody done this? Any tricks?
Old Apr 4, 2016 | 01:00 AM
leaking air into the intake manifold, or leaking gas?
Old Apr 4, 2016 | 04:36 AM
Czakky's Avatar
It's leaking a little bit of gas out of the manifold.
Old Apr 4, 2016 | 12:45 PM
injector seals normally keep air out, as the manifold is normally below atmospheric pressure. any extra air that is sucked in around the injector messes with the mixture as it doesn't get metered, so it causes the engine to run too lean , its usually a bigger problem at low throttle/rpms as the amount of air taht leaks is usually quite small.
you didn't mention which year/model/nationality this is, 240/740/940 have used several different fuel injection sysstems over the years, and world market cars often differ from North American cars in a variety of ways. also, if it is a turbo or not could be an important factor.
where exactly is the fuel leaking out? between the injector and fuel rail (lh injection) or fuel line (ke injection)? or between the injector and manifold ?
Old Apr 4, 2016 | 01:01 PM
Czakky's Avatar
Sorry I thought that my sig showed my car. 86 US 240 non turbo. The gas is leaking between the manifold and the injector.
Old Apr 4, 2016 | 03:02 PM
huh, is this mostly at idle, or is it when revved up? at idle there should be a strong vacuum in the manifold (like -9 psi) such that it would be sucking air in, not dribbling fuel out.
also those air leaks make for very poor idling.
Old Apr 4, 2016 | 03:21 PM
Czakky's Avatar
Seems worse when cold, but there is definite fuel leaking. Hard to say if it's worse at speed. There had always been a pretty poor negative crank pressure (doesn't suck much). Even though I've replaced oil separator/flame trap. But it does idle ok not buttery smooth but steady.
Old Apr 4, 2016 | 03:24 PM
crankcase pressure has nothing to do with manifold vacuum.
one of my mercedes had several leaky injector seals, the symptoms were stalling when you tried to accelerate from a full stop, it required a very gentle touch on the throttle to prevent stumble-stall.
Old Apr 4, 2016 | 03:29 PM
Czakky's Avatar
Doesn't the crankcase get neg pressure from the intake side?...
Old Apr 4, 2016 | 03:33 PM
i'd have to look closely at the 240 plumbing to verify this, but most cars, the crankcase ventilation goes into the air path *before* the throttle body, but after the mass air flow meter. there's no significant vacuum before the throttle.
Old Apr 4, 2016 | 05:29 PM
Czakky's Avatar
I understand never thought about it that hard. Either way I think I'm replacing the seals on the injectors. Pretty straightforward?
Old Apr 4, 2016 | 05:34 PM
lev's Avatar
lev
Yes, nothing to it! An untrained monkey can do it in a couple of minutes, (Youtube).
Old Apr 4, 2016 | 09:57 PM
definitely plan on replacing all 4 injector's seals.
Old Apr 9, 2016 | 05:59 PM
Czakky's Avatar
Just an update. All 4 seals in (nothing to it really) at start up looked like #2 was still leaking. Let her warm up and it looks like she's holding, though I won't be confident for a while. Just for the heck of it I pulled the plugs and #2 did look more rich than the others (nothing concerning). I also cleaned electric connections while I was there. We'll just have to wait and see.
Also the vacuum routing for the flame trap is big hose after MAS before throttle body. Little hose is right on the intake manifold. At least that's how mine is.
koko284
Mar 1, 2012 08:46 PM
BlueVanACD2005
Engine & Internal
Apr 17, 2010 06:33 AM
holobox
Sep 3, 2009 07:12 AM
soprano46
May 12, 2005 10:07 PM
RLeighton
Jan 12, 2004 07:12 PM
