Is this a fuel issue?
Old Jun 23, 2009 | 10:00 AM
qstyle's Avatar
Default Is this a fuel issue?
Hello everyone,
Ive read other threads here but my problem seems to be a little different. I have a 82 245DL wagon 2.1L w/ k-jet. Basically the other day when i left the grocery store and got in my car , started it and i heard the whining from the pump in back which is always there but this time the whining was intermittent like it was cutting out in spurts. I started backing out of the parking space and i noticed it was hesitating/bucking severely. Now i only live about a mile away so i just went for it. The car stalled at least 7 times and was acting like it was running out of gas but i had 1/2 tank. Needless to say i barely made it home and its been sitting for a few days. I just went out and started it right up and the whining from the pump is back to normal and its running fine now, i even revved it up several times with no cut out or hesitation. Im pretty sure the in-tank pump has been replaced within the last 10k miles but im not sure of the main outside. I was under the impression that pumps either work or they dont so why would it pretty much fail 1 day and the next start right up and act normal. Granted i havent driven it as im afraid the same thing will happen. The fuel filter, spark plugs/wires, air filter, o2 sensor, dist. cap/ rotor are all pretty much new. What do you guys think?
Qstyle
Matt
Old Jun 23, 2009 | 10:12 AM
adub96's Avatar
Probably the in tank pump. You heard the main pump whining louder because it was possibly starving for fuel. Sometimes when you first start a car up that has a bad pump, it will run fine, as the pump warms up it will degrade in performance because it starts spinning slower.
Old Jun 23, 2009 | 12:36 PM
qstyle's Avatar
thanks, that seems to be a good place to start and its cheaper than the main although i'll probably do that as well here soon.
Matt
Old Jun 23, 2009 | 09:59 PM
varg's Avatar
I had a similar problem (minus the noise). The hose on the in-tank pump that connects it to the metal line on the pump/float assembly was rotted to nothing and it was sucking air below 1/2 tank or on acceleration (fuel sloshing will cause the car to buck, mine did). It ran ok with a full tank though. I'll go with adub and say pull the in-tank pump and check everything out, chances are this is where the problem lies
Old Jun 24, 2009 | 12:54 PM
qstyle's Avatar
Thanks for the help guys , much appreciated. I checked the electrical at the pre- pump and it was fine so im pretty sure the pump is done. Im ordering a new one + new hose, clamps, filter so i can get it done right.
Matt
acpenn
Feb 25, 2014 06:50 PM
Earthfromorbit
Jun 15, 2011 03:14 PM
AnEskimo
May 15, 2011 12:32 AM
orcutd
Sep 27, 2008 08:13 PM
abstract
Sep 25, 2007 08:58 PM
