Fuel line replacement
Old Sep 10, 2009 | 02:26 PM
picstl88's Avatar
Default Fuel line replacement
Anyone offer advice on replacing the rigid fuel line between the fuel pump and fuel filter on a 1988 240 DL wagon. I have a leak at the brass connection from the pump after replacing the fuel filter.
Thanks!!
Old Sep 10, 2009 | 03:14 PM
adub96's Avatar
uhmm High pressure fuel line from an auto parts store would probably do the trick.
Old Sep 10, 2009 | 03:22 PM
bubba240's Avatar
http://www.fcpgroton.com/product-exe...ategory_id/149
make sure to use new washers.
Old Sep 10, 2009 | 03:28 PM
adub96's Avatar
OHh that one, you people with your fancy second pump and fuel filter under the car.
Old Sep 11, 2009 | 07:34 PM
Typhoon's Avatar
It's just nylon/teflon fuel line. Get a new piece, cut old line off with razor blade, put on new line, heat ends with heat gun. Done!
Or teh high pessure fuel injection hose and a couple of clamps will work well too, slice old hose off and you have two nice hose barbs to slide teh line on to.
Regards, Andrew.
smithnr
Apr 8, 2013 04:56 PM
CoVoVo
Oct 24, 2012 10:19 PM
charlesd
Dec 31, 2008 01:59 PM
Hamptons1
Oct 4, 2008 08:50 PM
ronad1
May 16, 2008 03:51 PM
