fuel problem?
Old Sep 3, 2016 | 09:46 PM
beleive's Avatar
Default fuel problem?
Well try to keep this short. Few weeks ago my 90 Volvo 240 the car broke down and ended up being the CPS. It has ran fine for 2 weeks until today. I went out to leave and would not start. I did a diagnostics with the LED to check igntion with no problems showed. I manually checked for spark by removing sparkplug and grounding it. It has good spark. What is the best way to check fuel pumps. Or anyt thoughts what could be wrong. Oh yeh, the motor has good compression. Thanks for any help. My wife is wanting me to get rid of it. Im not ready for that. Thanks
Old Sep 4, 2016 | 08:16 AM
act1292's Avatar
First thing to check is if your fuel pumps are working. Turn your ignition key from the off to the II position but don't crank the engine. You should hear the fuel pump run for a second or two. If not, then check the fuses and the fuel pump relay.
Try this site for diagnosing fuel pump problems: In the Tank - 240 Volvo Tank Pump and Sender
Old Sep 4, 2016 | 09:05 AM
Volvodok's Avatar
Also if the date code on the relay is more than 5 years old,time for a new one.
Old Sep 4, 2016 | 10:50 AM
lev's Avatar
lev
I have many FI relays dating back to the '80s that are still just fine. But I do carry a spare.... relays are not affected by time.
Old Sep 4, 2016 | 11:21 AM
act1292's Avatar
Most failures of the relays are due to cracked solder joints on the little circuit board of the relay. The cracking is most likely due to vibration over time. The original relays lasted around 10-12 years on my cars at which point they would start to fail intermittently. My resoldered relays are still running so I don't have a longevity measurement yet.
Old Sep 4, 2016 | 10:26 PM
beleive's Avatar
well its fixed. It was the fuel pump relay. Thanks for the help. Im going to order another one fo a spare.
smithnr
Apr 8, 2013 04:56 PM
orcutd
Sep 27, 2008 08:13 PM
the_happy_driver
Jun 26, 2008 12:47 AM
chaniewski
Nov 13, 2007 05:50 PM
edahlgren
Oct 7, 2005 09:53 PM
