Fuel sistem weird problem
Old Nov 27, 2012 | 06:19 PM
Paramedic835PR's Avatar
Default Fuel sistem weird problem
Ok, here's the deal. I got a 1990 740 GLE non-turbo and I'm having this weird issue that as soon as the car reaches half a tank of gas it starts acting like it is out of gas and as soon as it goes below half a tank it will shut down and not start until I put gas on it. the funny thing is that it has gas on it, a half tank to be exact and still it won't start if it has less than half a tank. What can be causing this ? Otherwise the car works like a champ until it reaches half a tank.
Old Nov 28, 2012 | 12:35 AM
lev's Avatar
lev
I believe you have the B234 motor. 16v. It's a little different but the fuel issue should hold. you have either bad in tank pump, or the hose lifting the gas from the tank is split. Either way, the fuel pump/sender assembly have to come out. You can do it, but it's challenging and a little messy.
Andreslunam
Apr 16, 2015 10:57 PM
cabdoctor
Sep 25, 2014 09:29 PM
swiftjustice44
Oct 25, 2012 06:32 AM
checos
May 21, 2010 12:04 AM
Joao Medeiros
Mar 9, 2009 07:35 PM
