fuel system 84 volvo 244
Old Apr 8, 2012 | 11:02 PM
Amber Wa's Avatar
Smile fuel system 84 volvo 244
Hi I have a strange problem with my 84 Volvo 244 2.3 GLE. I was driving the other day and my car just stalled out. I parked it and tried to start it again and it would turn over but wouldn't start. I was parked by the side of a very busy street and couldn't tell weather the pump was turning on. I figured out that it wasn't getting fuel. So I bought a filter and was going to see if that would fix the problem. The pump and the filter are both attatched to a plate next to the fuel tank. So I unattatch the plate from the underside of the car. I was going to release the pressure in the system so I figured I out to at least try to start it and low and behold the son of a bee sting started right up but since I removed the fuse for the fuel pump it surged and then died. I relplaced the fuse and the dang car ran fine. I got under the car and lifted the pump and filter back into place and the car died. So I thought maybe it was the wires I wriggled them to see if that would make the car stall but it didnt. I felt the gas hose that connected to the pump and I could feel and hear a rough clicking sound when the car was running with the fuel pump hanging down as I lift up the pump and filter the clicking stops and the car dies. Any one that has any ideas i would love to hear them
Thank You
Old Apr 9, 2012 | 03:59 PM
Amber Wa's Avatar
Default more info
So I figured out when the metal frame that holds the pump and filter touches the car I can hear an electric sound and that is what shuts off the car. It has something to do with the electrical connection. I checked the relay it is fine. But from there I dont know what to do.
Old Apr 10, 2012 | 12:34 AM
joshofalltrades's Avatar
thats a strange one. its a fairly common problem to have the pump stop running because of a bad ground connection, but i've never heard of it stopping for grounding its body. all i can think of that would cause this is an electrical failure inside the pump where the hot wire is shorted to the body of the pump. i new pump would be advised, though it may be possible to insulate the pump against the car body to keep it going for now.
Old Apr 10, 2012 | 06:26 AM
act1292's Avatar
If I remember correctly, the pump does not get its ground through the chassis. It is mounted on rubber posts to keep pump vibration from resonating on the chassis and making lots of noise. Instead, it has two wires running to it - one being ground. My guess is that one of the wires has a break in it that flexing it causes it to make/break a connection. Or it could be loose or corroded connections on the pump. If you have a voltmeter, disconnect the wires from the pump and test the hot lead by jumpering the fuse as describe here:
In the Tank - 240 Volvo Tank Pump and Sender
Move the wire around and see if you lose the voltage on it. You can do the same with the ground wire using the ohmmeter to the chassis ground.
Good luck
Old Apr 10, 2012 | 05:25 PM
Amber Wa's Avatar
Thumbs up
Thank you for your great feedback, I'm going to give it a go today, and I'll let you all know how it goes. Thanks peeps.
mphilleo
Sep 28, 2013 05:59 AM
inilegna
Sep 25, 2013 03:27 PM
mfrancis
Mar 3, 2012 11:22 AM
jmotrain
Apr 8, 2011 10:24 PM
