Fuse/ Washer fluid
Old Oct 18, 2005 | 04:51 PM
colgate41's Avatar
Default Fuse/ Washer fluid
Two questions, My winshield washer fluid does not come out anymore, and i filled it up and there are no leaks. The wipers go on when i pull the leaver but no fluid comes out. I had the hood open as i was changing my oil and i pulled the leaver and the fluid came out again, then i closed the hood and no go, what is up?
Also I went to autozone today to try and get a new fuse for the fuel pump relay and they looked at me funny. Where can i get this little block of a fuse?
Thanks again.
Old Oct 18, 2005 | 09:34 PM
Default RE: Fuse/ Washer fluid
Did the hose get pinched somewhere?
Also disconnect hose from the valve on the hood and see if it comes out. First though you might want to listen for the motor and see if it is running.
What fuse is it that you are looking for?
Old Oct 19, 2005 | 03:04 AM
colgate41's Avatar
The fuse that controls the fule pump i think.
Old Oct 19, 2005 | 08:43 PM
Regular blade fuse?
Old Oct 20, 2005 | 08:13 PM
colgate41's Avatar
Back to the washer problems. I dont hear anything at all anymore from the pump, but also where is the winshield washer pump located, maybe if i could find it i could fix it.
Old Oct 20, 2005 | 09:30 PM
Black Beauty T4's Avatar
Agree with Tech, if opening the bonnet/hood improved things, then a pinched hose seems the most likely cause.
I don't have this model, but most washer fluid motors are attached to the windshield washer resevoir. Have an assistant operate the washers (ignition on but engine off), while you listen under the hood for the "whining" of the little washer motor. If you hear it then the motor & elec. supply are good & a blocked or pinched hose (or a blocked washer nozzle) most likely cause.
BB
Old Oct 20, 2005 | 09:35 PM
Yes the washer motor is located in the washer bottle. It should be on the bottom of the bottle.
Old Oct 20, 2005 | 09:48 PM
colgate41's Avatar
Thanks again, ill check it out.
p.s. Get that 740 Tech
Old Oct 20, 2005 | 10:11 PM
Its actually a 1989 760 Turbo!!
audiotx
Sep 13, 2012 07:52 PM
keithlovestogolf
Jan 30, 2012 11:47 AM
mischief4l
Sep 2, 2008 07:13 PM
97volvo850
Aug 27, 2006 12:11 PM
Bklyn
Jan 11, 2006 12:28 AM
