fuses keep blowing...associated with shiftlock?
Old Oct 16, 2009 | 08:08 AM
briang232000's Avatar
Default fuses keep blowing...associated with shiftlock?
Hi all,
I have a 93 240 that my 7th fuse (shiftlock and apparently ALL lights) continues to blow on. The first time that the fuse blew was about a month and a half ago. Replaced the fuse-everything seemed fine. About a week later, my gear shifter would not shift out of park, but the fuse did not blow. I noticed the shifter was wobbly, and I now have to make sure that a little pin is in the white plastic bushing before the car will crank and/or shift into gear.
3 days ago the #7 fuse blew again, rendering me without lights, so I replaced it. It blew again this morning. Has this ever happened to any of you, and if so, can you tell me what is going on? Thanks.
Old Oct 16, 2009 | 09:28 AM
blue goose's Avatar
Take a look at the neutral safety switch. Here is a photo writeup by Art Benstein:
http://cleanflametrap.com/neutsw.html
Old Oct 16, 2009 | 10:59 AM
bubba240's Avatar
You'll probably want to remove the shifter cover and look for shorts.
Attached Thumbnails fuses keep blowing...associated with shiftlock?-shiftlock.jpg   fuses keep blowing...associated with shiftlock?-shiftlock2.jpg
rbarri2
Aug 6, 2014 12:28 PM
smokeyV70
Jun 15, 2013 08:17 AM
Capo Cam
Mar 13, 2009 08:20 PM
vegedge
May 31, 2007 10:46 AM
liberty
Jul 19, 2006 08:44 PM
