Gas leak on 1994 940
Old Feb 4, 2018 | 03:43 PM
katman104's Avatar
Question Gas leak on 1994 940
I have a leak in a hose that connects the plastic pipe from the gas tank to a shrader valve under the center left hand side. Does anyone know the proper part name I should order for it? Thanks in advance for any help. I believe it is 3/8" inside diameter or 11MM.
Old Feb 5, 2018 | 03:45 PM
tony1963's Avatar
Picture?
Old Feb 6, 2018 | 05:24 PM
katman104's Avatar
Originally Posted by tony1963
Picture?
Here is the picture'
I believe this is going to be a 12mm high pressure line. The boot is not necessary in my opinion. Bought some 3/8 hose and it would not fit. According to Volvo this line is supposed to be 15/32 MM inside dimension. Will go to town tomorrow and try to find some MM high pressure hose and if not will buy some 1/2" inside diameter and see if it will work. Will keep the post updated as I work on it. Having a rainy season now and unable to work n it.
Old Feb 6, 2018 | 08:44 PM
make sure whatever fuel hose you get is A) metric and B) fuel injection rated.
where is this in relation to the fuel filter ? is this car a Regina or Bosch system (is there a fuel pump next to the fuel filter under the car?)
Old Feb 9, 2018 | 08:35 AM
katman104's Avatar
Default Gas leak on 1994 940
The hose is between the tank and Fuel filter. the fuel filter is located under the car next to the Fuel pump. Is this a Regina or bosh I do not know the difference.
There is no supply house in my town that handles metric size at all. Bought a piece of fuel hose yesterday that is 1/2" rated at 300PSI. According to the salesman this hose does not require being High Pressure at this point in the system.
Old Feb 9, 2018 | 03:09 PM
I believe thats part 16 on this drawing (shown in an inset)
the parts catalog notes say, 240mm long but don't give the hose diameter.
Cboyz
Jun 26, 2017 02:36 PM
jeffrisley
Jun 14, 2015 01:48 PM
frustrator-bolt
Dec 18, 2009 12:20 PM
1999S80T6
Dec 16, 2008 04:54 AM
marty.otoole
Apr 1, 2008 09:10 AM
