happy happy joy joy.. check engine?!?
Old Aug 3, 2014 | 01:20 AM
Default happy happy joy joy.. check engine?!?
argh. my 92 745 Turbo just threw its first CEL codes in ages when I was coming home just now.
3-1-2 on #2 and 2-4-1 on #6.
I'm reading that as knock sensor disconnected, and an EGR failure. i'll do the egr mity-vac tests in the morning, its dark out, ditto try and find the knock wire.
Old Aug 3, 2014 | 08:16 AM
dnarby's Avatar
I replaced a knock sensor in a brick last year, no biggie. I think you're supposed to torque it to a spec. EGR I dunno. Interesting that the FAQ doesn't indicate the CEL should go on.
Old Aug 3, 2014 | 12:03 PM
not sure I trust the FAQ for California specific stuff like EGR
I know the EGR drill. start engine, mity-vac the egr control hose, and trhe engine should almost stall. use DTM3 on the ignition system and the EGR actuator should pulse.
Old Aug 5, 2014 | 12:37 PM
and, yeah, looks to be sketchy vacuum hose between the EGR control valve and the actuator thing. I need to get some 4.2mm vacuum hose, local store only had american sizes, which were either too small or too big :-/
pierce
Sep 16, 2014 03:28 PM
Fuddy Duddy
Mar 24, 2011 05:37 AM
racinghen
Oct 5, 2009 10:33 AM
djamp1983
Nov 24, 2008 12:53 PM
AshevilleXC70
Aug 16, 2005 10:39 PM
