hard reverse
Old Jan 15, 2008 | 12:21 AM
bobble's Avatar
Default hard reverse
I have a shifting problem on my 1987 245 GL. Intermittently, and to varying degrees, the transmission feels like it is meeting some kind of physical resistence when in reverse only. Sometimes I have to use quite a bit of power to roll it, sometimes it will roll at idle. It isn't like an overrev/slip problem. The transmission and diff have been serviced recently.
Has anybody seen this problem? I was wondering if a worn propeller shaft center bearing, worn u-joint, or maybe a hanging brake caliper ( or e-brake shoe) could cause this.
Old Jan 15, 2008 | 12:57 PM
tedv's Avatar
Default RE: hard reverse
I have seen it in other cars, brakes hanging in reverse and causing the symptom. Does the car roll freely backward/forward in neutral? Play with it like that and that may give you some clues. If it meets resistance in neutral then it has nothing to do with the trans.
Old Jan 17, 2008 | 10:41 AM
bobble's Avatar
Thanks tedv, that helped. It does meet resistance in neutral so that helps with troubleshooting. I've inspected the brakes and everything functions correctly. When I pulled the wheels, though, the problem wasn't present so I can't rule out the brakes just yet. I know the center bearing is worn so I guess I'll replace that first and go from there.
underaroof
Sep 6, 2013 09:35 AM
mrfry
May 29, 2013 08:35 PM
tr_car_nut
Sep 11, 2011 01:56 PM
daver80
Jul 13, 2009 10:19 PM
jerryman
May 23, 2006 01:19 AM
